Question about Technics SL-1210 Turntable
How to remove a Technics sl- db20 platter
I'm trying to remove my Technics sl- db20 platter to put the turntable band back on but can't seem to remove it. Can anyone please help?
Thanks,
A
  • Anonymous Mar 16, 2014
    how do i remove platter
  • Anonymous Mar 25, 2014
    Hi there, I have recently changed the belt on a SL-B210. Now when the platter turns, one side catches on the motor as it turns round.
Pull
Posted on Jul 28, 2008
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Apr 01, 2014 | Technics SL-1200M3D Turntable
How do I remove the platter on a sl-bd22 Technics turntable?
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Jul 12, 2010 | Technics SL-BD22 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
I have just a basic belt drive turntable and the belt fell off.... i need help on how to put it back on
Hi There.
If the belt falls of the platter, it might be an indication that the belt has stretched and is now too large. Or maybe it just fell off for any other reason.
Remove the rubber mat, and pull upwards on the platter to remove it. Sometimes there is a small "C" clip on the center spindle that has to be removed first. (use a small flat screwdriver to remove)
Turn platter over, and put rubber belt around diameter ring on underside of platter. It should be snug, and not fall off when you turn platter over.
Put platter back onto turntable, and spin by hand until you see the motor shaft through one of the holes in platter.
With a pair of tweezers - or crochet hook, put belt over shaft.
You're done.
Put back rubber mat and give it a try.
Good luck,
Fred
PS: If there was a "C" clip, you can re-install it - or throw it away.
Aug 14, 2009 | Technics SL-BD22 Turntable
Removing the platter to oil the motor shaft
hi .... get any object ( like hammer, or handle or wood) tap slight on the middle spindle of your turntable until become loose,...
May 28, 2009 | Technics SL-1200MK2 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
How to replace drive belt for model.# SL-BD22 ?
Nope, very simple...
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Feb 28, 2009 | Technics SL-BD22 Turntable
I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 01, 2009 | Technics SL-1210 Turntable
Removing platter
I removed the rubber pad from platter.There is two round holes in platter lift platter by grasping these
holes. wolf545
Dec 14, 2008 | Technics SL-1210 Turntable
How do i put my belt back on a technics dc servo automatic turntable system SL-B210 i havnt used it for a while so when i got it out to use the belt was lose uder the thing the disc gose on
Remove the platter, then take the belt, and wrap it to the bottom lip of the platter. You'll see an inner lip underneath the platter... this is where the belt goes.
Next, put the platter back on, and you'll see 2 holes on alternate sides of the platter. Rotate the platter until the brass shaft of the motor is exposed - usually @ the 11 o'clock position. Pinch the belt and pull it out, to wrap around the shaft.
That's it.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 21, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
422 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
