Question about Samsung ML 2010 Laser Printer
Not feed paper
My printer goes on and attenpts to feed the paper but the black cog in the center of the printer will not grab the paper and feed it through the printer.  I believe that I need a new black cog in the center of the metal bar for the paper to properly feed.  I dont understand why I have this problem because I have printer very little paper through this printer.
  • benscorsa Aug 09, 2008
    exactly the same
    An expert who has answered 500 questions.
  • 564 Answers
It may be that the paper is too slick for the grabber to access...try a little heavier bond paper(not the same as copier paper, which is SLICK.
Posted on Aug 18, 2008
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The photopaper tray goes in, but the printer feed cant grab the paper. it is the correct direction, so i don't know whats going on.
Sometimes the printer does not feed the paper because it is too thick. Try to check the GSM of the photo paper, it should be 180 or 235.
Jun 27, 2011 | Office Equipment & Supplies
Paper not feeding properly, sometimes it goes through crooked and sometimes it isn't grabbed and put through printer
The little wheels that 'grab' the paper sometimes become too smooth and will simply slip on paper. There is wheel rejuvenator you might find at a local stationary store or you might want to try an alcohol soaked q-tip on the wheels.
Dec 02, 2009 | Canon PIXMA iP90v Printer
Paper won't load straight
you will need tools, remove back cover and clean rollers and maunually rotate. hope that helps
Oct 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printer no longer feeds paper from paper tray; I tried cleaning it, it sounds like the printer is trying to grab the paper but it does not grab it.
Remove the paper tray. Use a lint-free cloth dampened with rubbing alcohol (isopropyl) to wipe all around the black "rubberish" wheels right underneath the unit where paper tray goes. I learned that by calling Okidata.
Oct 05, 2009 | OKI C3400n Laser Printer
1610 all in one.....won't grab paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.cf725f2.jpg
Jan 30, 2009 | HP PSC 1610v All-in-One Printer
Lexmark x2480
Is it pulling through only on the right?
Or left?
Either way [sounds like] it needs taking apart to put the paper feeder cogs back inline.
To the right would suggest the easier option of the bar which is visible from where the paper exits has dislodged and the cogs sit on the left hand side of it.
As the paper feeds through it's unlikely the other option as those cogs are what feeds the paper through but they are intricate so it can't be ruled out.
Not much fun if you don't like doing mechanical maintenance I guess!
Aug 01, 2008 | Office Equipment & Supplies
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Paper feed problem.
I have just removed the panel where the power and USB cable lock into. It's a case of 1 screww from the rear and 2 catchs underneath the printer. From there you should be able to see the mechanism for the roller, a set of small white cogs. below that you should be able to see a very small spring which is acting as the pressure. Mine was still attached but as you say was pulling no pressure on the roller what so ever.
Find yourself a large-ish rubber band and slip the band over the whole mechansim. Best way is through the paper feed slot, slip it over the roller and then move it through to the area where you removed the panel. Position the rubber band as far down the cogs as possible, don't worry the cog casing prevents the band interfearing with the cogs. Now pull the band reasonably tight and with the other hand test the pressure of the roller. Adjust till you feel OK with it. Now put the panel back in with the end of the rubber band trapped and poking out from the panel behind the printer, holding it in place. Redo the screw and give it a try.
My first attempt found it a bit too restrictive and feeded to sheets at a time but adjusted it once and its back to normal. I know its a bodge but its a cheap one and it uses a rubber band, just how I fixed my Punto's windscreen wiper, £120 part or a rubber band once a month... Mmmm...
Jan 22, 2008 | Lexmark P4350 All-In-One InkJet Printer
Samsung ML 2010 Laser Printer Logo
504 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
