Question about Lexmark X73 All-In-One InkJet Printer
Faxing Is the Lexmark x73 a fax machine?
WEll the x7350 is a fax and scanner and copier plus printer. Which x73 do you have?
Posted on Aug 20, 2008
We can't receive a fax!!! how are we supose to connect with a phne line and the computer???
You don't need to have a computer plugged in to the Lexmark printer to receive faxes. Here's an article on How to Configure the Lexmark X7170 to Receive Faxes. Just click on this link: http://bit.ly/d643uT. If you are sharing your home phone line with the fax and you have an answering machine on the same line, make sure to configure the answering machine to pick up first then the fax machine. Voicemail feature can also block incoming faxes. Once voicemail picks up the fax, signal won't be passed on to the printer. But if you want, you can also contact Lexmark technical support to further investigate the problem.
Aug 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
ERROR 940 DE LEXMARK 352DN
y lexmark x73 manual de impresora lexmark t612 lexmark z710 free driver lexmark cartouches imprimantes gros lexmark 4270 error 1203 tiger direct lexmark fax ...
www.chippewacountyabstract.com/.../information.php?id=lexmark -
Dec 03, 2009 | Lexmark E 352dn Mono Laser Printer
Print directly, not print to file
Is a PostScript printer listed as one of your printers? If so, it may be the "default" printer (notice a little black checkmark next to it in the "Printers and Faxes Folder". To change default printer:
Control panel --> Printers and Faxes --> Find your printer in the list, RIGHT CLICK on top of it and choose "Make Default Printer".
Hope this helps!
-- RT
Sep 01, 2009 | Lexmark X73 All-In-One InkJet Printer
I have here a Lexmark X73 copying machine,fax,scan,e-mail and I am tring to get it connected to my tower which is HP pavillion could you help me with this hook up
jfergie, did your computer give you an error message or you are in the initial method on getting this one working on your computer?
Sep 12, 2008 | Lexmark Office Equipment & Supplies
X5495 wont receive a fax - can send one though..
that means that the fax machine on the other end, can't read your handshake from lexmark. Happens.
www.lexmark.com has the drivers you'll need by model and operating system
http://tinyurl.com/6qcpgy
Aug 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Scanner, files,and the faxing screen
You downloaded wrong drivers:::
please use this link to download and install the software:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:0:0:0
Mar 06, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X73 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
