Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
DVD disk problem
I cannot get my disk out of the tv no matter what I try..
  • 3 more comments
  • JeffMcc5 Aug 17, 2008
    We loaded our first DVD and it will not play nor can we get it out of the reader. We have hit the eject button on the front of the TV and the button on the side and the remote and nothing works. I can see a blue light in the DVD reader but it basically does nothing..
  • eedan Oct 30, 2008
    Same problem. A disc was playing and suddenly froze. Tried to eject, turned tv on and off, nothing. Any suggestions?
  • Anonymous Nov 22, 2008
    Westinghouse 40" 1080p LCD TV/DVD Combo -
    // Can't eject the dvd
  • Anonymous Dec 29, 2008
    Very same problem - turned off tv and nothing works.  And the DVD is a rented movie:(
  • Anonymous Jan 07, 2009
    Have the same problem...any advice besides turning it off and on again???
I had the same problem and was irritated and even emailed Westinghouse. I unplugged the TV and turned it back on and held the eject button and it worked. I am not sure this will work for everyone or if it was luck. It was stuck for 2 days.
Posted on Jan 08, 2009
  • anonymomo May 03, 2011
    This solution worked for me as well. Thank you for the suggestion, it truly helped me in making my son happy.
Turn the TV off. Try ejecting the disc.
Posted on Aug 29, 2008
Why is there an error message: Space Not Enough when trying to copy DVD?
There is some space reserved for dvd information, error information etc. So solution is make the file archive by right click on file ->proprties-> click archive. After that use winrar and compress. http://www.rarlab.com/download.htm
Aug 22, 2013 | EZ Dupe Computers & Internet
When I first got it both blu ray and DVD worked now it only plays some some disks. It will say error check disk and then the movie comes out.
This is listed under a Flat Panel TV problem solution request so am I right in assuming you suspect the TV?
If so...you should first disconnect your Bluray Player and try it on any other TV with AV inputs to see if it soes the same thing. If it does then read on.
I suggest you could try two things. First is to wash the DVD in warm soapy water using a clean soft cloth and rinse it clean and dry it with a lint free cotton teatowel. Then do a visual check of it after drying it. Make sure it is blemish free and has no foreign matter deposits on its surface. You can use a SMALL drop of Methylated Spirit on the cloth to remove tough deposits... But do not use it on the Label side of the disk. Once it is pristine clean. Try it in the player again.
If still no luck, purchase a CD cleaning kit which has a bottle of cleaner fluid with it and follow the instructions carefully to clean the laser lens in your disc player.
As you can play some disks only, the above seems a likely solution.
Note that if you have non-original cd's
/dvd's many of them are of dubious integrity and may not play properly......so discard them.
Jun 29, 2011 | Televison & Video
Hello, I have a Magnavox DVD Recorder mwr10d6. I want to burn some movies to play in it. What format of CD's do I need and does it matter if it's avi, mpg, mov, mp4 or not. What are these anyway? Thanks!
avi, mpg, mov, mp4, these are all video files. you can use almost any cd-r band. dvd movies require use of dvd-r disks. some dvd-r disks are not playable in all players.
Nov 18, 2009 | Philips Magnavox DVD Player MWD200F
Bad disk error no matter what disk is played.
try a cotton swab and len cleaner. rub a small amount on the laser eye and then dry it off. do thus several times. be careful and don't put to much on the cotton swab. it don't take alot
May 01, 2009 | Televison & Video
Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is...
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
Oct 22, 2008 | Computers & Internet
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Bad disc message display
when disk is in dvd message reads bad disk.
Apr 22, 2008 | Televison & Video
Samsung HT-TX72 Home theater system - Disk Error
Try updating your firmware... samsung.com Or have you tried that?
Dec 05, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Televison & Video Logo
332 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
