Garmin GPSMAP 60Cx GPS Receiver Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I am using Garmin GPSmap 60Cx, the waypoints and track data need to be download from it to my laptop, how to download data by usb port(serial port to usb compatible cable available)? thank you!
Anonymous
Level 2:
  • Expert 464 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
Answers
464
Questions
0
Helped
119241
Points
696
There are serial to USB adapters that can be purchased so you will still be able to load the GPX datum off your unit. Here is a link to one http://www.gpscity.ca/gilsson-serial-to-usb-port-4in-adapter-for-pc-and-mac.html.
Hope this helps!
I was collecting waypoints with a Garmin GPS 72H. Because of low battery it got shut down. Then I on it and when I was about to record the location by pressing enter button the device again got shut d
From the saved data when you backed it up on the computer. Use Garmin Express to transfer.
How to Backup User Data from GPS 72/76 or GPSMAP 76/76S
https://support.garmin.com > en-CA
It is recommended to occasionally back up the user data on your GPS 72/76 or GPSMAP 76/76S. User data includes waypoints, routes, tracks, and geocaches.
4helpful
My garmin 530hcx has locked up on the opening screen...is there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 • Garmin GPS
1helpful
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
http://www.youtube.com/gpscity#p/search/6/8ddIgvCAUmI
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
http://www.gpscity.com/gilsson-serial-to-usb-port-4in-adapter-for-pc-and-mac.html
1helpful
My Garmin gpsmap 60cx will not proceed past the welcome screen
I'd pull the microSD and see if it boots.
If so, reseat the microSD and see if it boots. If so, good. If not, try reformatting and loading the data back on.
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
GARMIN 60CX Contour Map display: Sent maps to unit OK. Then was able to display a WayPoint with its contours. However... later, now able to display WayPoint but NOT surrounding contours. The Map IS...
The topo maps are low in the map hierarchy. If another mapset is loaded at the same time and is also checked it will likely "cover" topo. I think the Recreation maps are the only one's lower in the hierarchy.
1helpful
A stolen GPSMAP 60Cx is it posible to locate it once it is turned on???
Sorry, no. Report serial number and internal ID number(if known) to Garmin and the Police. If a map is ever unlocked for it or it comes in for repair at least Garmin will know.
GPSmap 176 not communicating with laptop via serial/USB adaptor
sounds you do not have appropriate usb driver so find download and install usb driver from following website:
http://www.usb-drivers.com/
chose your compute product to make sure about USB driver.
Inputs Wrong Waypoints
Enter like this...
12 S 0415660 3812882
This point is south of I-17 near Humbolt AZ
Trouble connecting to any computer
Hmmm..
Make sure your using a USB cable, specifically a USB cable with a mini connector on the end. Specifically, a USB cable with the second one from the left in this picture:
http://en.wikipedia.org/wiki/Image:USB_types_2.jpg
If you are using the USB port, you should have no need for setting COM ports.
Another technique you can use (which I just figured out today) was to place the Garmin Unit in "USB Mass Storage Mode". This allows you to offload saved tracks, but I don't think you can download waypoints or other things that the WayPoint Manager allows.
You can access this option via the Garmin Unit
Goto: "Main Menu" -> "Setup" -> "Interface". Press Down to get to the button "USB Mass Storage". Plug in that USB Mini cord, and you have a thumb drive!
Good Luck!
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
