Question about HP OfficeJet 7310 All-In-One InkJet Printer
Officejet 7310: Scanner Failure
My machine is out of warranty. From the beginning it has had issues with scanning but now even printing results in a "scanner failure." The cost to have HP fix it just doesn't seem like a smart investment. I was hoping someone could tell me what the part is and whether a savvy tech person could swap it out. It apears to be a hardware issue but no idea how to fix it. From the boards,this seems to be a popular issue with this product.
Any thoughts? My HP Officejet 7310xi All-in-One dials, connects with number, secures connection and then starts to scan the document to be Faxed. It then displays "Scanner failure" and makes a "Musicoid, whirrrr" sound. The print, scan, and copy features work very well. A "Scanner Failure" message appears. It directs that the power should be turned off and restored after about 20 to 30 seconds. All instructions were followed. The machine was cleaned. The bulb works well. New software was downloaded. No improvement has happened. The Fax does not work at all.
sandbur@aol.com; 07/27/2008.
  • 1 more comment
  • sandbur Jul 27, 2008
    My HP Officejet 7310xi All-in-One dials, connects with number, secures connection and then starts to scan the document to be Faxed. It then displays "Scanner failure" and makes a "Musicoid, whirrrr" sound. The print, scan, and copy features work very well. A "Scanner Failure" message appears. It directs that the power should be turned off and restored after about 20 to 30 seconds. All instructions were followed. The machine was cleaned. The bulb works well. New software was downloaded. No improvement has happened. The Fax does not work at all. Scanner Lamp is just fine.
    All other functions of the device perform fine. scanner copies. Printer works fine. Fax does not work. I notice many complaints Online about the HP Officejet 7310xi All-in-One Fax.
    Thanks for advice; cleaned all and rechecked equipment. Have very clean glass. Good bulb in place. No apparent mechanical deficiencies. Still get Error Message of "Scanner Failure" and directions to recycle power. Fax not possible at present. Receive Faxes fine. Copy from glass fine. Print fine. Copy from Feeder fine. This problem seems not very uncommon to me. I hope the company, or someone, can come up with a solution.
    Thanks,
    Sandbur@aol.com
  • 3,037 Answers
Usually with this kind of printer, the individual parts can't be bought. Also like you said, not worth sending it in. Depending on how long you have had this printer, the wise choice would be to get a new one. If you go this route, HP has a habit of giving a trade in discount but you need to call them about one and order it through their sales department not from a store. Let me know if you really don't wish to do this and I will see what other options may fix this problem but like I said, getting a new one is the best bet. If you have any other questions, please let me know
good luck
Posted on Jul 27, 2008
  • 2,071 Answers
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light. If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product . Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
  2. Make a color copy by pressing the Start Copy Color button on the control panel.
  3. If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
  4. Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Unplug the power cord from the product.
  2. Press and hold # and 3 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel. If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
  2. Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
  • 2 more comments
  • LORETO LACARON
    LORETO LACARON Jul 27, 2008
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
  • LORETO LACARON
  • LORETO LACARON
  • HP Master
  • 6,487 Answers
Try this one...
1. The button control panel locking "button" is not so much a button as it is a "latch" - located just to the right of center at the bottom of the panel.
2. Make sure all ribbons and cables are properly seated and out of the way of moving parts before resetting the top.
3. The source of the problem seemed to be the cleanliness of the underside of the glass closest to the scanner motor - ours was extremely clouded for some reason. I read in another thread that the scanner carriage can't tell that it's "home" unless it can clearly read the white line on the underside of the scanner table.
4. I also cleaned and lubricated the rod, belt, gears, and carriage - which I'm sure didn't hurt but not sure helped.
5. Took me 3 or 4 tries before carriage finally found "home" and unit worked.
Hope that helps..............
  • Mark Gil
    Mark Gil Jul 27, 2008
    Yes there's really alot of problem with this unit and almost all clients ended up replacing it..
  • Mark Gil
    Do a semi-full reset will reset on your printer
    Press and hold Cancel and the Left Arrow key while plugging in the power cord.
    Good luck...........
  • HP Master
  • 19,396 Answers
Probably it is the scanner lamp faulty
  • Ginko
    Ginko Jul 27, 2008
    Check if the lamp starts, if it does not it is the lamp, and must be replaced, If lamp is ok it is a problem with the belt or the mechanics, in this case the printer must be taken apart to find out what is wrong and eventually fix it.
Hp 7310 prints but receiving error message scanner failed. I turned it on and on and unplug still scanner failure but it prints from computer???
hi there!
if its a scan issue, you may need to uninstall/reinstall hp printer software. or check on the scan bed if the light is coming out when you turn on the printer. check out this link too, this have all the info you need and tech support for that printer:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=391182
Apr 07, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Every time I turn on my officejet 7310 printer a warning comes up saying scanner failure. I cannot do anything with it. I uninstalled it & reinstalled it but with no luck getting it to work> ...
Sometimes you can clean the scanner optics and get a little more life from it, but it involves taking the glass off the top and cleaning the scan unit mirrors and lenses. When that doesn't work you need to locate a new scan assembly, last check, around $150.00
Aug 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure-no longer prints
Hi, I'll give your situation a "stab in the dark" solution. It sounds like you are in the final stages of "scanner system failure". The beginning stages usually limits the all-n-1 to print only i.e., no scan and no fax but you may have such a severe scanner bulb situation that is preventing the print function and may be causing hazardous conditions within your printer and it will do nothing to prevent further harm or damage. Can you describe your situation a bit more detailed?
Apr 16, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 7310 All-In-One giving a dark line one scans and copies
I had the same problem but figured it out. Both sections of the top of the printer open and under the left side there is a separate "scanner window" that you can't see unless you open that side. lift your regular scan tray and then pull the left side up (it opens out to the left) and then left the piece that is under it. You should be able to see the thin scanner window. You can clean it with rubbing alcohol or even windex.
Feb 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
238 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
