Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
EX-Z60 1.01 UPDATE
HOW DO I INSTALL UPDATE MY CASIO EX-Z60 WITH UPDATE 1.01 to ROOT MEM.IN CAMERA? I HAVE DOWNLOADED IT TO MY PC ALSO I HAVE IT ON AN SD CARD. THANKS
Put the new 1.01 update file (not the zip file) in your mmc. Then start the cam with pressing the menu button same time with on/off button.
Cam will ask you if it's ok to update firmware, just select ok and there you go :)
Just make sure you have battery fulle before doing this update.
Posted on Sep 17, 2008
Today I found a firmware update v102 for the EX-S200 Silver model. I want to update this firmware as the color of the picture taken is extremely bad compared to a 3 year old Nikon 10 megapixel. My less...
I doubt this will take care of the problem. The root directory of the drive is the removeable sd card from the camera and it is above the level of the BIN folder. You then plug the sd card back in the camera and hold down the set button. The whole process is outlined http://support.casio.com/download.php?rgn=1&cid=001&pid=987
Mar 01, 2017 | Cameras
I have a casio ex z500. I bought a 8gb sdhc card and it didn't work, so I downloaded the 1.02 version. It takes pictures but now when I insert the card in the memory slot on my computer, the computer is...
The EX-Z500 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
Feb 26, 2011 | Casio Exilim EX-Z500 Digital Camera
I have a Casio Exilim ex-z40 camera and tried to install a 4 GB memory card. The camera says "Card Error". Will this camera take a 4 GB card or should I stick with the 2 GB I have in it now?
The EX-Z40 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to stick with SD cards, 2GB and smaller.
Feb 13, 2011 | Casio Cameras
How big of an SD card can I use with my Casio EX-Z750 Camera? I'd like to use a 4 GB or 8 GB but was warned they may not work. Can't find this info on the Casio site, and don't want to waste money on...
The Z750 uses SD cards and is limited to 2GB cards. 4GB and up cards are SDHC (Secure Digital High Capacity) cards and do not work in devices designed for SD cards. This is a hardware issue and cannot be upgraded in firmware.
SD cards will work in SDHC devices, but not the other way around.
Jan 19, 2010 | Casio Exilim EX-Z750 Digital Camera
CASIO camera says screen card is locked, mem. card is on unlock..
thank you very much, it was the card when i removed the card it worked. again thank you
Jun 06, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Camera Memory Card Capacity
Hi there, and welcome to FixYa.
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
Rob
Mar 02, 2009 | Casio Exilim EX-Z750 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Memory card issue
First off what is the size of the mem card? Second did you make sure that you formatted the mem card with the camera before you tried to use it? What I would recommed is transfer your files to your computer FIRST. Then format the internal memory of the camera once you have transfered them over. Insert your memory card and then format the mem card. Turn the camera off and take your mem card out. Try taking a video. Turn off camera. Put mem card back in and see if you can transfer that video now and it should work.
May 02, 2008 | Casio Exilim EX-Z57 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
245 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
