Question about Emerson Black Microwave Oven
Door is not open
Hi sir i have emerson mw89915b bat sum how door is not open help me plese thank you
  • aileenyjesus Sep 21, 2008
    door is not open
  • Emerson Master
  • 9,098 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Many Emerson microwave manuals are available for free download here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Dear Sirs We have a emerson microwave model MW8778W manufactured in 2002. The problem we have is that it doesn't power up any more. We have tried using another plug outlet but are still experiencing the...
The main fuse in the microwave oven has blown, sometimes you can change it without a problem, but normally I find the door switch becomes defective causing the fuse to open. If you decide to service it yourself be very careful of dangerous high voltages that are present.
Feb 07, 2011 | Emerson Microwave Ovens
Hi, My GE microwave oven model no. JVM1850CD 002 stopped heating a few days ago, and now has a dull sound to it. Prior to this it had been working great. Your help is much appreciated. Thank You, Regards,...
Please check the door safety interlock switches which you will find opposite the door hinge. Check them with a volt./ohm meter. You will hnave to remove the cover. Dont fool with the start capacitor.
What typically happens, Richard, is if you open the door while the oven is working, the switches arc and will eventually burn to the point that they cannot complete the circuit. When this happens, the oven thinks the door is open and it will not turn on the heat (magnatron).
Find replacement parts at FixYa.com advertiser, local source in your community or at www.repairclinic.com
Thanks for posting your question at FixYa.com and plese vote
Thank you
a
Nov 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
900E Microwave Oven Door Won't Open even after
Your latch has come apart inside the door or inside the oven. Probably a spring separated or broke.
Remove the cover --WATCH OUT FOR THE SILVER CAN - LETHAL -- and try to release the lock that way. I think you will be able to open it from inside but I also think your trouble is inside the door, though I dont have experience on this model. If the trouble is in the door, you will have to disassemble it. Look for hidden screws or a plastic strip which must be removed to separate the door halves.
Good luck in your project.
Oct 19, 2009 | Emerson Black Microwave Oven
Emerson microwave oven
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
May 24, 2009 | Microwave Ovens
My emerson microwave has stopped heating up but appears fine
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | Emerson Microwave Ovens
EMERSON MW8998B
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Aug 26, 2008 | Emerson Black Microwave Oven
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
Emerson Black Microwave Oven Logo
126 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
