Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Evaporator coils iceing over; warminhg on frig side of model 106....
'Replaced bi-metal per your instructions to madezmom. 'Ohmed old & new bi-metal (warm, open circuit; cold, closed circuit). Replace it anyway. Ohmed defrost heating coil; 0 ohms, closed circuit,should heat. Fan runs fine as does the compressor. I do not know where the defrost timer is. 'On the control board assy.?
Thanks
  • Chris Ski
    Chris Ski May 11, 2010
    Fan broken?
As I said; the fan and compressor run fine but I cannot find the defrost timer. Is it integrated into the control board.
Thanks
Posted on Jul 30, 2008
Kitchenaid Side by Side refrigerator
Check the defrost heater for continuity.
Jun 26, 2013 | Refrigerators
Fridge not cooling freezer is
Your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
May 17, 2012 | GE Monogram Side by Side Refrigerator
Ge gss25kgmccc. frig not cooling
If you mean the machine is freezing, but not cooling then the first thing to check is if the evaporator fan located in the freezer is running, If its not then thats the problem, but if it is see if you notice any frost on the back wall, if so
Your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute. Your particular model has what they call glass heaters, pt #WR51X10055, and are notorious for burn out. You'll have to thaw it out, but when you do remove the back panel and you'll be able to visually see if the heater is burnt out or not.
May 09, 2012 | GE Refrigerators
Every few days the freezer side of a side-by-side refrigerator freezes over (ice on coils), while the refrigerator side is warm. The thermostat has been replaced, but problem continues. Any troubles
Defrost timer pt# 215846602
Defrost heater pt # 218169802
Defrost thermostat pt # 297216600
Apr 30, 2012 | Frigidaire Refrigerators
1 month old whirlpool refrigator is almost 60 degrees in frig part and 10 below zero in freezer side
It sounds like one of two things, either the evaporator fan is not running(fan in the back of the freezer behind lower back panel) or the bi-metal thermostat that may be in series with it is open..
Also some newer models use a lower voltage fan motor, use to be all were 120 volts........
It is under warranty for one year so call for authorized service to repair it......
(all of the cooling on the refrigerator side is done by air circulating from the freezer side, also possible there is ice blocking the air flow somewhere)
hope this helps
Feb 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Frezzer is icing up and frig is getting warm . we tried to defrost by shutting down. we did this twice model #msd2957de
Hi, If you are having frost build up, you will need to remove the rear panel inside the freezer. Unplug the refrigerator. You will need to test the bi-metal switch that is located on top of the evaporator coil and it needs to be cold when testing it. If the bi-metal switch shows an open circuit, it will need to be replaced. If the switch shows a closed circuit, test the defrost heater the same way.
If both parts show they are ok, you will need to replace the defrost control which is located inside the fresh food section in the control panel.
If it is solid ice that you find after removing the freezer panel. the drain under the evaporator coil is plugged and will need cleaned out.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
136 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
