Sewing machine Model 385. 1284180
The bobbin constantly jams and the thread tension doesn't adjust correctly.
  • rjkorb Jul 27, 2008
    I continue to have problems with the bobbin jamming and the tension not adjusting properly even after the tension is set according to the owners manual recommendation. I continue to have problems with the bobbin after the machine has been cleaned and oiled.
  • rjkorb Jul 28, 2008
    so far, all the comments seem to just state the obvious.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
The thread is tangling in the bobbin area either because the machine has some lint in the bobbin area or under the feeddog plate. It could also be having a tension problem, but first clip all of the threads loose and pull them out. Then use a small sewing machine brush to clean out all loose thread and lint. If the feed dog plate will not just lift up, you may have to take out a screw. A can of air like is used on electronic equipment will help to blast out the lint your brush can't get. The machine also needs periodic oiling. Check your owner's manual for oiling points.
thanks
good luck
Don't forget to rate the solution
Posted on Jul 28, 2008
    Master:
  • 497 Answers
Ensure a sharp and new needle,check ur thread line and bobbin are free from lint and jam,try setting ur tension to 4 and then suit ur bobbin.
  • Yaz  S
    Yaz S Jul 28, 2008
    TOP THREAD TENSION:
    If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
    projects).
    IS YOUR NEEDLE SHARP ?
    If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
    TOP TENSION & GUIDES:
    Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
    It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
    If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
    Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
    a see saw / to and fro action.
    In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
    disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
    BOBBIN TENSION:
    Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
    I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
    the hook race area (where bobbin case sits)
    ...this is just good housekeeping, my wife does this every time she replaces the bobbin....
    just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
    Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
    If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
    TOP LOADER:
    Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
    ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
    FRONT LOADER:
    ....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
    back properly.
    FINISHING UP
    GETTING THE BALANCE RIGHT:
    When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
    Try using good quality thread of contrasting colours so you can more easily spot the changes.
    Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
    a time, perhaps 1/16 of a turn.
    You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
    and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
    OTHER ISSUES:
    If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
    case....no case ? then make some sort of cover !
    Same applies in any damp or humid environment, keep your machine dry and dust free.
    Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
    dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
    FINALLY, A WORD ON THREAD:
    If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
    time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
    a fellow member had posted this on our site....Thanks for using Fixya
  • 2,071 Answers
Change the bobbin maybe it is already misalign, that causing to jam..
Hope this may help;
Posted on Jul 27, 2008
  • LORETO LACARON
    LORETO LACARON Jul 28, 2008
    Did
    you put the bobbin in the right way round? Is the ends of the threads nice and long before
    you start sewing
    and are you holding them as you start sewing? Some machines have a
    slight tendency to 'eat' the thread tails as you start sewing if they
    are too short or not held.
    Using the instructions in the manual,
    thoroughly clean the
    entire machine, and oil all designated spots.
    Clean the thread path, using lint free heavy thread or cord,
    especially between the tension disks.
    Remove the bobbin, and if possible the bobbin case and use a
    soft brush to clean all areas of the case, lubricate if the
    manual instructs you to do so, re-insert the bobbin case.
    With the presser foot UP, thread the needle path, including
    the needle.
    Place a properly wound bobbin in the bobbin case, thread the
    bobbin path (and once again, have the manual open to the
    threading diagram and be sure you are catching the thread
    under/over EVERY spring/slot/opening), leaving a 6" tail.
    Holding the end of the *needle* thread in your left hand,
    and with your right hand manually turn the flywheel (again
    be sure you are turning it in the right direction, refer to
    your manual) a full turn, until the needle goes down, picks
    up the bobbin thread, and brings it up. Place BOTH threads
    between the toes and to the rear of the presser foot, being
    sure you leave at least 6".
    Place your fabric under the presser foot, lower the foot.
    Holding the thread tails firmly with your *left* hand,
    slowly start to sew.
    If none of this works, you may have to take your machine
    back to the shop where you bought it for service and
    lessons/instructions.
    Just click below for the picture guides
    and instructions;
    eBay Guides - HOW TO FIX YOUR SEWING MACHINE IN 5
    EASY STEPS
    Fix It Club | Small Appliances | Sewing Machine
    Repair
    Don't forget to rate;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
  • 6,487 Answers
Are you helping feed the fabric through? Even with the "auto feed" on most household sewing machines, you need to pull the fabric through it doesn't really feed through itself.
Or you could have the tension improperly set on the thread, or the bobbin could be improperly threaded. I've had sewing machines jam up when too much thread "lint" gets caught up around the bobbin mechanism too and it needs to be cleaned out to run correctly again.
Such bunching can also happen if you're running too heavy of a fabric through and there just isn't enough clearance under the foot for it to move easily.
Hope that helps..........
  • Mark Gil
    Mark Gil Jul 27, 2008
    This machine should be take to a repair center and let them do the fixing because that can be a problem with the motor...
    Good luck........
  • Mark Gil
    Mark Gil Jul 28, 2008
    If you still have problem with the bobbin have you tried replacing it....
I notice the thread from the bobbin is loser than the one coming directly from the spool. Also, one side of the stitching seems normal and the other side seems like a long single stitch
That is tension. Sounds like you need to tighten the upper tension slightly to bring the bobbin thread up. The tension is correct when the upper and bobbin threads meet in the middle of the fabric. Also, tension will not always be constant. It may need to change as you change fabrics, thread, and as your machine ages, so it is best to get comfortable with adjusting the tension for each project.
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
How to Adjust the Tension on Sewing Machine
Jan 13, 2017 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
Kenmore bobbin issues
try these suggestions
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Oct 25, 2012 | Kenmore Sewing Machines
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
Too many threads coming up from the bobbin
try rethread the machine top & bobbin
change the needle
clean under the needle plate & in the bobbin area for lint & loose
threads
Aug 04, 2012 | Brother LS-2125 Mechanical Sewing Machine
Singer5050 sews a little then jams top thread in pieces in bobbin area
Start from the begining.
Use your Instruction Book and make sure the machine is threaded correctly.
Put in a new needle.
Adjust the top tension to about halfway.
Fit a fresh wound bobbin that does not have all sorts of different threads still wound on it(a bad habit with a lot of people).
Make sure the bottom tension is correct.
Make sure the bobbin is fitted corectly.
Set the machine to do basic straight stitch(mid range stitch length).
Try sewing and see if the problem is solved.
Apr 19, 2012 | Singer 8280 Mechanical Sewing Machine
I have a Viking/Lisa Model. I am having trouble with my tension and I am not sure if it is the top or bottom. My bobbin thread is all of the sudden too loose.
I just bought a Viking Lisa, and also had to adjust the tension. Use the manual to make sure you've threaded the machine correctly and put the bobbin in correctly. (I wasn't getting the bobbin thread the way it needed to be.) Then gradually increase the tension on the dial inside the top cover, checking the bobbin stitches every two inches, ending up on about 4 1/2. If this doesn't take care of the problem completely, gradually increase the side tension dial, and between adjustments on both dials, you should end up where the stitches look good. Also make sure to use cotton thread; mine doesn't like polyester thread. :o)
Aug 20, 2011 | Husqvarna Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
The bobbin thread is sewing loose stitches and jamming the machine. I have re-threaded everything, brushed out the bobbin casing, changed needles, adjusted thread and bobbin tension, and am stuck and...
Always have the presser foot up when you thead any sewing machine.
Make sure the flat side of the needle shaft is facing to the back of the machine.
Don't do anything to the bobbin tension. Set the top thread tension to what is recommended by the mfg.
Make sure the thread from the bobbin is feeding from the bobbin in the correct direction and through the correct guides.
After inserting the bobbin and threading the machine, lower the needle (hold on to the thread tail) and then raise it by turning the hand wheel by hand to pull up the bobbin thread.
Gently pull the two threads under the presser foot and to the back of the sewing machine before you begin to sew.
Feb 19, 2010 | Singer 3116 Simple
Thread bunching and jamming in bobbin area
what you have is known as bird nesting and is from the needle tension not being tight enough
before you thread the needle pull the thread and the correct tension is when there is noticeable resistance to pulling the thread
always check adjustments using scrap material
Nov 11, 2017 | Kenmore Sewing Machines
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
