Compare CCA...(Cold Cranking Amps) for the most reserve power. Try not to settle for less than 1000 CCA...There are limited true battery manufacturers...The most popular sellers based on Value are Costco, Autozone Duralast Gold, Walmart Maxx, Interstate, and AC Delco...you can limit your search to a factory brand from your Porsche dealer or compare others at a much higher price for less performance and guarantee. All of these will more than satisfy the reserve power needs of your Carrera...Hope this helps. (For selling value, the factory battery is usually best on high value cars like yours:)
SOURCE: 911 carrera sc2 has hard time starting when rain
sounds like moisture is getting in the way of your spark ,how old are the plugleads,dist cap etc,all get affected by water as they get older.
SOURCE: I need Porsche 911 SC\Carrera heater blower motor
there are lots of dismantlers like partsheaven. or you can go through pelican parts.
SOURCE: 2004 911 carrera has been in storage fo 5 months.
If the engine turns over but does not start the first thing to check would be fuel pump, and or fuel injectors.
SOURCE: Porsche 2000 911 Carrera. Key fob problem
each vehicle is different put the key in the ign. turn key on press door lock/unlock at the same timehold button for 10 sec see if any lights on the dash inst. panel blink if they do that means that the key fob was programmed to your vehicle i recommend a new key fob this will give you definative instructions on how to reprogram your fob
