Question about Whirlpool Kitchen Ranges
WHIRLPOOL OVEN RF315PXGWO ELECTRIC OVEN ELECTRONIC CONTROL KEEPS BEEPING WITH ERROR CODE AFTER HURRICANE HAD POWER OUT FOR 4 DAYS HOW I RESET IT
SOURCE: electric oven range not working
I put my 12 year old self-claening oven on ,afterwards I tried to open the door and it will not open. I set it again to go thru the self- cleaning cycle and noticed the cleaning light was not on during the cycle. The oven is clean and it will work,I can't open the door.
I have cleaned the model number off. I can' seem to find another number,except for the one on the diagram on the back of the stove. There are two different numbers 316063400 and316002052. can you help me?
Posted on Jan 25, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Posted on Mar 24, 2009
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
rylee_smith
  • 8619 Answers
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
There was a power outage a few days ago and our Whirlpool Super Capacity 465 is reading an F1 E1 and will not stop beeping. What should I do?
Hello & Welcome to FixYa
Error code F1_E1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
43 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
