Question about Goodman CKL60AR60 Air Conditioner
Blower i have tried to figure out what is going on with my ac unit i just tried to turn the heater on and the blower still would not come on the compressor will come on but the blower will not come on
  • 182 Answers
Could be wiring,the motor or the control board.
Posted on Jul 29, 2008
CONTROLLER IS NOT WORKING BUT AC BLOWER IS DIRECTLY STARTED BUT COMPRESSOR NOT STARTED
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Conditioning Tamarac
Apr 11, 2016 | LG Window Ac Unit 18000 Btu, Energy Star...
Sell and light smoke coming from A/C compressor when heater turned on.
I'm not familiar with that code but, the A/C compresser is supposed to come on with the de-frost setting. Sounds like it could be a problem with the heater A/C control panel. As for the burning smell,it could be dust burning off the heater core, or possibly your blower motor trying to go out.
Mar 10, 2014 | Dodge Ram 2500 Cars & Trucks
When i turn my heater on (blower) my car tries to stall out. What can cause that to happen?
most likely your ac compressor is locked up. see if you can disconnect ac compressor clutch at compressor. if problem goes away, you can use heater without any problems..
Dec 15, 2012 | 2004 Dodge Stratus
Problem with Air Conditioner
there will be an access panel where the motor is located. 1st thing to check is fuse or circuit breaker feeding the air handler. this is on seperate power from compressor unit outside and usually has a fused or breakered disconnect on the side of the unit. if fuses are good or breaker is not tripped then switch fan mode to on. if blower runs in on but not in auto then it is a thermostat problem. if still no go then turn off power, remove access panel and find the squirrel cage fan blade. make sure it turns freely. it is very common for these motors to go bad. it can usually be removed easily and taken to a motor shop. I use Roy's Electric in Richmond, Va. They can test the motor on the bench and replace it if it is faulty.
Sep 08, 2012 | Heating & Cooling
2000 acura tl ac heater fan wont turn on
my acura tl fan turn on when i turn on air conditioning why
Aug 22, 2012 | 2000 Acura TL
Heater/ac blower ...all sound no blow
or you trying to use the A/C if you are then have the compressor checked and the freon level checked also last summer had the same problem with my truck gave it a quick charge and it worked just fine so they maybe the problem
Mar 18, 2012 | 1996 Volvo 960
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Aug 04, 2009 | BMW 328 Cars & Trucks
Blower will not turn on when a/c compressor comes on - tstat ok fuses ok
You should have a fan relay on your furnace that would control your fan in air conditioning and that sounds like you are needing
May 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
Feb 12, 2009 | Ruud UAMB Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
67 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
