Question about Polaroid FLM-3201 Television
No signal cannot get signal on tv remote will not clear it up or reset tv
  • 44 Answers
Can you get a signal manually? can you play a dvd or vcr through the tv?
I need more information
Lou Margolis
Allied Electronics
Posted on Aug 14, 2008
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
First of all make sure all the leads are connected to the TV.
Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
Now you will need to perform an all channel search.
Press the Menu key to display the main menu.
Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
Now you may need to perform a digital cable search to pick up your satelite digital signal.
Press the tuner key on the remote and then the menu key.
Use the cursor key to select Digital cable search and press enter.
Now the TV should scan for a digital signal
Good luck and kind regards.
Jun 25, 2010 | Televison & Video
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
FLM-323B HD blue screen, no signal.
for the remote change battery or get new remote, For the TV make sure that your cable is plugged in properly and not half out. or has it previously been wet. Reason because it sounds like your TV has had a static charge.
Jul 03, 2009 | Polaroid FLM-323B Television
Picture size problem
is there a way to reset the tv remote and how do you clear the remote before you start the coding procedure?
I have an rca tv.
Sep 08, 2008 | RCA HD56W66 56" HDTV
AKia pdp-4249g
Apr 16, 2008 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
Same problem
unlock is in the tv menu not remote if you still have owners book that came with tv it will tell you how
Feb 03, 2008 | RCA TruFlat 27F520T 27" TV
Yes, I seem to have fixed the problem on my Akai using some creative google finds. One of two things worked - not sure which:
1. Leave the set unplugged overnight - it must let the electronics reset when the residual charges clear
2. For my Akai (remotes and models vary), hit in remote's sequence quickly - brightness, freeze, menu, enter - this places you in some screen that offers a hard reset option. That didn't work right away, but i did it before the option above and then the set worked again.
My problem was really odd because it worked for the component inputs and you could see the video and TV signals inside the PIP windows, but not full screen as primary input. Why the TV could 'see' the signals in a PIP windows but not detect them as primary I have no idea.
Oct 13, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Sep 23, 2007 | Sanyo AVM-3659S 36" TV
Polaroid FLM-3201 Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
