Question about Thermador SC302T Electric Double Oven
Thermador model scd302t4 double oven, It appears my problem is pretty common. the display is very dim. i think the control board needs replaced, the part is no longer available. thanks for any solutions. the oven works but the display face is dark. very unreadable.
  • Megan Webb
    Megan Webb Aug 08, 2019
    Good Morning,
    We have control boards for this model in our inventory for sale, and we rebuild them. We can repair the dimming display, or replace the glass display if needed. All control boards we sell and repair are fully tested for 100% functionality & come with a two year warranty.
    Reach out to us for more information.
    512-355-1108
    fixyourboard.com
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Feb 23, 2011
    Habit-Forming:
    New Friend:
  • 53 Answers
Good Morning,
512-355-1108
fixyourboard.com
thermador model scd302t4 double oven, - ch0509451 702451-crjxtk2pui4xc5qqbhljddcq-3-0_0.jpg
Posted on Aug 08, 2019
SOURCE:
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
Nov 16, 2009 | Thermador SEC302 Electric Double Oven
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Nov 23, 2006 | Thermador SMW272 Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
386 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Thermador Oven Expert? Answer questions, earn points and help others
