Question about Sony Televison & Video
Channels three and four arenot available on the TV at the moment. I have rescanned but they are still missing.
I spoke with your representative in Reading who was very helpful. It mabe a signal strength problem from Hannington that may resolve itself in due course.
Posted on Jul 28, 2008
Set up indoor antenna
Plug antenna cable directly into antenna input on tv. Place antenna where you believe you will get a signal (don't know where you live but you can look up site map for optimum direction). Go into tv menu set tv to air and auto scan air channels. Your set will receive and memorize available channels. In your sets menu you should have a strength meter. You can use this to tune in the strongest possible signal. You may have to go back and rescan the channels because if you improve the antennas position you might pick up more channels and they won't just come in automatically. Once you've scanned and received maximum number of channels there will be no need to rescan again. If you do you run the risk of losing some channels and only a rescan under optimum conditions with regards to antenna position and environmental conditions will gain those back. Keep in mind some fringe channels may come and go. Hope this helps.
Feb 01, 2015 | Televison & Video
Why is channel 17.1 and 17.2 missing?
I suggest you go to the MENU setting and do a 'rescan' to see if you get the channels back. You might need to readjust your antenna, or make sure that the storm yesterday didn't damage your antenna, cable or power interruption on your TV box. Good luck.
Sep 10, 2014 | Televison & Video
Why does my wharfedale digital tv keep sayind no infomation available on tv stations when i have not long tuned it in
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh
Sep 03, 2014 | Televison & Video
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
Toshiba 40 inch not pickingup channels in scan
Tuner is ng. You can check out the repair cost but ......Another option is to buy an external HD tuner and feed that signal to your set via HDMI inputs. Cheaper than a repair.
Available on ebay eBayeBay
Sep 13, 2017 | Lands Phones
I have a sony kp-57wv600 57 inch tv. and the channel button does not work. The channel button on the tv and the remote does not work. When I hit the channel button all that happens is the tv flickers but...
The first thing to do is to rescan for channels. If for some reason the channel memory got wiped out, there could be no other "available" channels to change to. The "flicker" you see is the TV changing to the same channel. Try the rescan and update this if that does not resolve the problem. Let's eliminate the simple stuff first. If the rescan DOES resolve the problem, please update this with that information as well and we will try to find out what cleared out the channel memory.
Thanks,
Dan
Aug 08, 2009 | Sony KP-57WV600 57" Rear Projection...
Insignia 32" will not scan all channels I only get 13 channels. how can I fix this??
Make sure the TV tuning mode is set for "cable". This will be somewhere in the TV's setup menus; check your manual for all the details. If it's set for "air" as I suspect it is, only the first 13 channels will be found when connected to cable. Channels 14 and up don't get tuned in on "air". Once you've set the TV for cable, rescan channels and you should have 'em all.
Thanks for asking here. If this solution has been what you needed, please take a moment to rate it!
Mar 12, 2009 | Insignia IS-LCDTV32 32 in. Television
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
Feb 19, 2009 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
