Question about HP Compaq Presario V2000 Notebook
Doesnt boot to windows
Can somebody help? my compaq turns on, but dons'nt boot to window.It will just show compaq amd stays there. I try the hard disk on another compaq and it work fine.Pls what might be the problem? Meze
  • 928 Answers
Normally this means there is a problem with either the memory or the board. You might have to do more isolation such as trying the memory on another computer etc.
Posted on Jul 27, 2008
My compaq presario/sr1750nx/ w sata drive/ amd 64 athlon. came with windows XP. I put put a new hard drive in the computer, with Windows 7 installed. I power up the tower, and the monitor stays blank?
It is very unlikely to get the machine working when the windows 7 HDD was installed in a different type of computer, because all drivers installed with the operating system are related to the hardware from the other computer.
The best solution is to make a clean install, using the windows installation disk, and after that to download from Compaq's site the latest drivers.
If you still have reasons to use that previous installation, you can try to do the following:
1. Boot from the Windows installation disk
2. Follow all steps until it discovers the previous installation on the HDD
3. Choose to repair it (or better upgrade, if this option is available).
But doing so there only 50-50 chances to get it work, or to get it to be stable.
Hope it helped.
Aug 20, 2011 | HP Compaq Presario Media Center SR1750NX...
When i turn it on i am asked to select one of two choices of operating systems(windows NT workstation version 4.0, or windows workstation version 4.0[VGA mode]) which one should i choose? whichever one i...
Yours problem can be system, or hardware.
First try in bios disable integrated pheriperals, like modem, lan, sound, and try boot.
If the trouble still here, try install new system with full format hard drive.
If you still have a problem, you have some hardware problem,something like procesor heathing.
Nov 02, 2009 | Compaq Armada 1700 Notebook
Getting a media test failure on initial boot up then windows blue screen pop up when windows tries to start. Is my video card not working properly? BIOS was reset.
probably hard drive failure.
try changing the boot order in bios.
if that doesnt work try reinstalling windows.
If windows doesn't reinstall then your hard drive is bad.
Oct 06, 2009 | Acer Aspire X1200 AMD Refurbished Desktop...
Can`t get think pad to boot windows
Feb 08, 2009 | IBM Axiom 20GB HDD ThinkPad 770 Series...
Windows will not start
You might have either a bad hard drive or a corrupted Windows installation (which could be due to a bad hard drive). You can try starting Windows in safe mode (press the F8 key when the Compaq logo comes up after you turn the power on, and pick Safe Mode from the list of startup options) if it will let you. Then try scanning the disk for errors.
You can also try using the Windows recovery console (assuming you have XP) to repair your installation. Boot the computer from the Window operating system CD (Compaq systems came with one; if you don't have one you can probably borrow one from somebody). After setup loads everything it needs you pick the "R" option to try repairing Windows. The "chkdsk /r" command sometimes is able to correct problems so that Windows can start again.
If necessary you can try restoring the original software, and replacing the hard drive if the disk problems continue.
Nov 19, 2008 | Compaq Presario 5000 PC Desktop
Not able to open windows
Sounds like a hard Drive problem. A virus actually. The Best thing to do if Safe Mode Failed is the Repair Your system, to do this insert your XP CD and wait until it says 'Press any key to boot CD' Press any key and follow instructions to repair windows. If it works, run a virus scan immediately. If Not, take it itno a computer technitian to look at it if you want the stuff on your Hard Drive, of if you feel you don't care too much just wipe the Hard Drive and Re-Install Windows XP. just do the same thing as repair but instead follow the instructions for Installing XP and choose either Clear or Erase Hard drive if you don't want the info or choose don't clrear or Erase if you really want stuff from your hard drive, But run a Virus scan Immediately asap.
Hope This Helps
Nov 18, 2008 | Compaq Presario M2000 Notebook
Not opening my laptop
Here's what you need to do to fix it: Find some way to get Partition Table Doctor ( and put it on either a live boot CD or from a secondary hard drive installation. Once you have that, Scan the partition for errors and select fix boot... Then if you're running Vista get a copy of Vista Recovery Disc ( burn yourself a copy of the disc, and run it at the boot of your computer. Once the cd is loaded, click on REPAIR WINDOWS, select COMMAND PROMPT, then use this command: bootrec.exe /fixboot
If that doesn't work use: bootrec.exe /rebuildbcd
and see if your windows boots.
IF you have windows XP, boot up with the Windows XP cd, select Repair (R), go into the command prompt (selecting which windows installation you want to modify) and then type this command: fixboot c:
See if your computer boots now.... The important thing is to try to repair your boot which has been deleted or corrupted, that is why it gives the error: err2err3
Try different recovery tools like Table Doctor in conjunction with your recovery cds (windows xp installation CD and Windows Vista Recovery Disc)
Jul 17, 2008 | HP Compaq Presario v3000z Notebook
Bootmgr error
theres several stages involving formating a disk.
this error however, appears to be discribing a boot-manager program.
Try booting with Windows in the actually DVD Drive.
If this does,nt work, re-format the hard-drive. or obtain a setup disk from your computers manufacturer.
i.e Compaq.
Mike @ Compurepair.
Feb 24, 2008 | Compaq Presario 2700 Series (222123-001)...
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
dear Tony please upgrade the your network system files
Aug 27, 2007 | HP Compaq Evo t20 Network Terminal
HP Compaq Presario V2000 Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
