Question about Dell Dimension 8300 PC Desktop
Amber light on power button
There is no beeping sound when powered on. fan is working, cd and dvd drive is working but no display on monitor is showing. green llight on mother board is on. amber light is blinking when power button is pushed. no diagnostic light showing in back.
  • cyn1245 Jul 27, 2008
    It doesn't work. I do notice that when the driver cable to the cd and dvd rom is plugged in the drivers don't work. When I take it off both drivers lit up. Is there something wrong my motherboard? I tried replacing the cable and still the same.
  • cyn1245 Jul 28, 2008
    still doesn't work.
  • 2,794 Answers
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Posted on Jul 27, 2008
  • Tim Babcock
    Tim Babcock Jul 27, 2008
    It's either the power supply or the motherboard. You might want to check the power supply first.
  • Tim Babcock
    Tim Babcock Jul 28, 2008
    The only option left is to replace the motherboard.
NO DISPLAY on screen but processor fan is work
If it seems like the computer booted up all the way except the screen is blank.
If so try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok and works, then the video card inside the computer is good, but the original monitor is bad. If the Borrowed monitor does not work, then the video card inside the computer is bad.
If it does not seem like the computer booted up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Jun 09, 2012 | Intel Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
I was just adding more storage to my pe 1800 and it started beeping. i.e long beep stop and then beep again. four amber light were on from the hard drive bay 2 to four being the new bay for the new...
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Beeping usually means a memory issue.
Jul 06, 2011 | Dell PowerEdge 1800 Server
Amber light flashing on switching on the pc why?
HI,
A blinking amber light means that there is a problem with the power supply or the motherboard. I know that could be a number of things. Perhaps you could give some additional information.
1) Does the green light come on on the motherboard?
2) Do any/all of the fans work? Power supply or computer cooling.
3) Do you get any other lights? CD/DVD player?
You may have to get someone to see if your power supply outputs are all good.
I hope that gives you some starting points.
Thanks for using Fixya.
Nov 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Solid amber power light
Your Monitor is not connected properly
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Connecting Your Monitor
1. Turn off your computer and unplug the power cord.
2. Connect the white connector end of the DVI cable attached on the monitor to the connectors on the computer.
3. Connect the USB cable that was included with your monitor to the computer and the upstream USB connector on the monitor. Once this cable is connected to the computer and the monitor, you can use the USB downstream on the monitor.
4. Connect any USB devices.
5. Connect the power cord.
6. Turn on your monitor and computer. If you do not see an image, see Troubleshooting Your Monitor.
NOTE: The Monitor will display full screen in White, Black, Red, Green and Blue color rolling pattern on screen if the DVI cable is not connected. This self test pattern will be displayed continually when Monitor detects that DVI cable from Monitor to PC is not connected.
* Check connection integrity at both ends of the video cable.
* Ensure the monitor and computer are plugged in to a working electrical outlet.
* Ensure power button is depressed fully.
Aug 14, 2008 | Computers & Internet
Dell Dimension 8300 PC Desktop Logo
404 people viewed this question
Alun Cox
