Question about Onkyo TX-SR605 Receiver
Onkyno receiver shuts off
My onkyno receiver shutss at about 42 decibels I just added 2 speakers to a 7.1 system My SR605 gets extremely hot. This is especially true when both amplifiers are running together supporting 2 separate channels. I added a 2 way speaker selector from Russound that supports 2 sets of 8 ohm speakers on Zone 2 and the receiver shuts down at about 74 dcbs and gets very hot. Checked the jumpers on the selector and they are set at 8ohms.
Have returned the Russound selector to them and had it checked out. Appears to be fine. Even when Zone 2 is not in use the receiver gets extremely hot. It is in a wood cabinet wih glass doors but even with the door open the temperture is very hot. As the volume is raise the heat increases and the receive trips off.
Very unusual in my opinion. Is this normel for the receiver to heat up as the volume is increased.
  • Onkyo Master
  • 19,396 Answers
The system is overheating
Posted on Jul 27, 2008
  • 2 more comments
  • Ginko
    Ginko Jul 27, 2008
    Your system is overheating, if it is piled underneath some other devices, remove them, if it keeps overheating you will need to have the termic sensor or the internal fan replaced.
  • Ginko
    Ginko Jul 27, 2008
    Heating up as the volume is increased is normal, the Amp waste more energy and dissipates more heat to produce higher volume signal.
  • Ginko
    Ginko Jul 27, 2008
    Check if your system has a fan, in this case that can be an easy fix, check also if system remains on with cover open.
  • Steve Oct 18, 2012
    I have the same problem with a Phillips receiver that has no fan. It is running hot and goes into standby. No dusk, debris or speaker wires touching each other. Would a laptop cooling unit work? If it is the sensor, how do you identify it and replace it?
My reciever keeps shutting of at a low volume, I have un plugged all the speakers and cables and it still shuts off. Any suggestions?
Hello,i suggest you do an up close inspection of the speaker terminals,i often find a small copper strand of speaker cable is shorting between the positive and negative cables.You will want to inspect both outside and inside the cabinet ,while unplugged of course.
Dec 15, 2010 | Onkyo TX-SR605 Receiver
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
Every time I try to turn on my onkyo receiver it turns off instantly
the reason why the receiver probably keep turning off is that the systems come with overload protector to keep one from burning or short the systems out so it shut its self off. make sure you have the speaker wires is connected properly, its very important that you do although the receiver has 0% tolerance when it come to speakers hook up. positive from speaker to positive connector behind reciever; same as negative. double check all speakers wires. repost if that not an issue
Oct 03, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
Blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Jan 09, 2009 | Onkyo TX-SR605 Receiver
Zone 2 must be on to hear zone 2
there are 2 ports for sub woofer, try using the other sub port.. I dont have to use zone 2, and not sure it even has a zone 2 sub port.... I use zone 2 for a cd player and speakers on the deck.. no sub woofer
Jan 02, 2009 | Onkyo TX-SR605 Receiver
Jun 22, 2008 | Onkyo TX-SR605 Receiver
Zone 2 Audio
help! screwed up z2 was working until i messed with it. do not know how to reactivate or even reset.
Apr 27, 2008 | Onkyo TX-SR605 Receiver
Rear speakers
THE 4 WIRES SHOULD BE FROM THE REAR SPEAKERS THEY GET WIRED INTO THE SURROUND SPEAKER OUT POSTS ON YOUR AMP (MAKE SURE YOU DO NOT GO INTO SURROUND BACK THIS IS FOR 6.1 AND 7.1 SYSTEMS).WHAT ARE THE WALL UNITS? NEED MORE INFO TO TRY TO HELP.
HOPE THIS HELPED A BIT.
CABLE GUY
Feb 13, 2008 | Onkyo TX-SR605 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
139 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
