Question about Kenmore 98702 Stacked Washer/Dryer
I tried it and it worked for about 20-30 sec and then it shuts off and won't cut back on for about 2-3 mins. Do you think it's still the timer? or the motor? Does the motor come under a different name? Thanks for your help.
  • 868 Answers
No its 100 % a burnt out motor.
Posted on Jul 27, 2008
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a kenmore washer/dryer combo.dryer runs but no heat
Try shutting breaker off FULLY!!! and then try again...
Often 1/2 trips, motor will still run, but no heat. Breaker not always evident, but click off (push fully off) and back on, and test again, also check for good air flow at the outside vent.
Oct 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer
make sure you have good air flow out the house if you do go ahead and change your thermostats and your high limit thermal switch.
Apr 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore model 98702
No - it is one body. it cannot be replaced - only repaired.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer keeps stopping, and a smell of smoke.
More than likely there is something locking up your motor. Either the transmission or the drain pump, both are connected to the motor. The easiest way is to disconnect the components from the motor to determine which one is causing the problem. Most of the time it is from the something being lodged in the pump, a sock, screw, wire, etc. To get to the pump you need to tip the washer back far enough to get underneath the washer.
Kenmore 98702 Stacked Washer/Dryer Logo
54 people viewed this question
Sal De
fordexpert
Robert Rankin
