Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Followed you instructions ...
Got my picture back but now it's "blinking." A brief blackout about once a second. Is there an adjustment?
MartyKZ
  • Martin Zitter Jul 29, 2008
    NO SOLUTION YET - Vizio P50HDM - Big bang! Got my picture back by replacing y and z boards but now it's blinking/flashing - brief blackout about once a second.
  • Martin Zitter Jul 31, 2008
    STILL HAVE PROBLEM - Vizio P50HDM - I replaced the y and z boards after "pop of death" and got my picture back but now it flickers/blinks. Is there an adjustment?
    Master:
  • 623 Answers
Try this number tel.[714]668-0588
e-mail techsupport@vinc.com
or
vizio 320a kalmus drive costa mesa,ca 92626
tel.[714]668.0588
web www.vizioce.com
Posted on Aug 04, 2008
    Master:
  • 555 Answers
What was the original problem with your unit?
Posted on Jul 29, 2008
TCL LED LCD 55" - Backlight issues
Repair or replace the backlight.
Nov 24, 2013 | Televison & Video
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Philips 50P8341 switch blinks 6 times stops and repeats 6 blinks
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 19, 2009 | Philips 50P8341 50" Rear Projection...
Can't adjust month/date etc....
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
Mar 10, 2009 | NexxTech Transparent LCD World Time Clock...
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Setting my digital watch
good morning ! to set the sharp watches is need to use the setting button ! first , press the adjust button up to 3 second after th digit blinking press the mode button to select the digit that you want to chagne and press the reset button to chagne tha digit to the corect time after setting press once the adjust button to time back to normal ! good luck ! ....
Sep 10, 2008 | Watches
Original problem ...
There are two additional Y Sustainer supporting Boards called the Upper and Lower Y Boards in the P50HDM that can also be replaced at the time of the Z and Y Replacement. There part numbers are: 6871QDH088A and 6871QDH089A. Although some techies prefer to replace them at the same time as the main Z & Y Boards you won't know if they are the problem unless you still have problems after the Z &Y are replaced at the same time. Since these are much cheaper than the Z & Y (about $50 each) that should take care of the blinking.
It sounds like you don't have the dreaded problem of busted panels otherwise you wouldn't have a picture at all. these boards are actually pretty cheap unlike the Z and Y which are a bit more expensive. It’s also popular to add two additional CPU fans to the unit for additional cooling. Apparently the POD (Pop of Death) has something to do with the main Z and Y overheating. To add additional CPU Fans, which are also pretty cheap, you’ll need a 3 Pin Y-Splitter (M-F) for the extra plugs to connect to the additional fans but be sure to purchase a super quiet fans since the additional fans will be running along with the two 5 inch super quiet fans that came with the unit.
Jul 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
96 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
