Question about Kenmore KBC12 Coffee Maker
Kenmore coffee Maker
Where can I purchase the charcoal filters for my coffee pot?
I have the Kenmore 00881666000 Mfg Model 238002WH Programmable 12 cup coffee maker. I could not find the filters and when I tried to order them online thru Sears, there was no match. I ended up finding out that you can get Cuisinart charcoal filters at Sears that are the same size and fit perfectly.
Posted on Oct 14, 2008
They are not available on the Sears online site at this point, but if you Google DCC-RWF, you can find a number of sites that have them available.
Posted on Feb 01, 2009
Go to the sears website and you can order them.
Posted on Sep 30, 2008
I need a replacement filter for my kenmore coffee maker item#69768
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
I need to purchase new filters for GE coffee-maker model number 169164
I'm not sure whether you mean the charcoal filters or the basket filter for the coffee. I have the exact same basket that I bought years ago as a replacement for a different pot, so I doubt that would be a problem. You can try your local Walmart for the charcoal filters since this model was sold exclusive contract with that chain. Depending on the size of your Walmart, you might have to special order those. Otherwise, they are available at most super centers. Just as an added measure, you might want to try washing the filters and using a coarser coffee grind before you buy new ones.
Dec 19, 2009 | GE 106591 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Coffee tastes like plastic!
We have had our DCC-1200 for 3 months. The plastic taste occurs about every 3rd pot, and it does NOT get better. We've wasted over a pound of coffee. Cuisinart says we are the only people in the world with the problem. Well, I guess not...
Jan 16, 2009 | Cuisinart DCC-1200 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Kenmore Elite coffeemaker water filter
http://www.kenmore.com/shc/s/p_10153_12605_00869768000P?filter=Price%7C%240-260%5E&vName=Appliances&cName=Small+Kitchen+Appliances&sName=Coffee%2C+Espresso+%26+Tea+Makers
Try here. Hope this helps.
Oct 08, 2007 | Coffee Makers & Espresso Machines
Kenmore KBC12 Coffee Maker Logo
451 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Steven Clarke
Steven Clarke
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
