Question about Electrolux EOG6330 Gas Single Oven
Electrolux gas single oven
Oven keeps shutting down. Takes several attempts to relight.
Due to safety feature you should have oven door closed,turn dial to 1,ignite then turn to 5or 6 hold it in for a few seconds and release.this should solve your problem
Posted on Sep 17, 2008
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
Turn on oven - but no gas. Is there a way to relight it?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 21, 2011 | Maytag CWG3100A Gas Single Oven
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
How to relight a kenmore oven it wont relight
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Gas oven takes long to heat and maintain temp. Also, there is often the smell of gas and a odd sound during the heating.
Faulty THERMOSTAT. Call a repairman to replace. If you attempt to locate and replace it, be sure to turn off all gas from the outside handle. You may have to relight all of your pilot lights, but its better than blowing yourself to the moon!
Oct 08, 2010 | Amana Ovens
We have a kenmore wall oven and we need to know how to relight it. it is g a gas oven.
your oven lest its very,very old dose not have a standing pilot.it lites by demand when you turn on
Jan 01, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Gas oven - fan constantly on
assume this is the casing fan. this is controlled by a fan stat which may be faulty. however, this fault should be covered under guarantee so call service agent
Apr 23, 2007 | Electrolux EOG6330 Gas Single Oven
Electrolux EOG6330 Gas Single Oven Logo
219 people viewed this question
Top Electrolux Ovens Experts
Electrolux
Electrolux
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
