Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
  • Anonymous Mar 25, 2014
    my whirlpool cabrio washing machine clanks when dispensing water
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
I am constantly getting LD error. What is this and what causes it?
Posted on Jun 25, 2010
Whirlpool Cabrio model WTW7300X washing machine
Did you inspect the area around the drum? You have to take the top off to do that. Then there is a water sensor on the left side. The error that you get is from the drum speed sensor.
Dec 16, 2013 | Whirlpool WTW7300X Top Load Washer
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Am getting a F51 error code
The electronic control displays an F51 code.
There is an intermittent connection at the Rotor Position Sensor, (RPS), causing the electronic control to indicate an F51 code.
Remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires.
If you still receive the error after this, replace the electronic control with part #W10130544. This new control is designed to check the RPS sensor differently and is less sensitive to intermittent RPS connections.
Dec 25, 2010 | Whirlpool Cabrio WTW6600SBK
My washer keeps displaying a code of f 51 what is the problem
Basically, the F51 error is a rotor position sensor error.
Thank You
Sep 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio is displaying F51 what is this
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. If you google whirlpool cabrio error code F51, you'll get an idea of what you are up against. This is obviously a manufacturer's defect. They should take care of this problem whether you are in warranty or not. If you are insistent, maybe they will. Contact whirlpool directly if you're not satisfied by your local service people. This is not a DIY job.
Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine - F51 code
F51 - This is a motor Rotation Positioning Sensor failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,084 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
