Wireless mouse all of a suddon stoped working. everything is plugged in fully charged , have tried the connect button along with many others. 7 button centrios laser mouse.
    Novelist:
  • 88 Answers
Nice mouse.
I've had some problems with wireless mice in the past, so I will just list the causes and see if one fits the bill for you.
1. Did you move the USB transceiver (this is the device that communicates with the mouse) from one USB port to another? If so, uninstall the mouse and reinstall it using the CD that came with your mouse.
2. Do you have any other wireless devices in the vicinity of your mouse that use a radio frequency rather than infrared, such as a wireless keyboard? If so, you may have a conflict.
3. Were you provided instructions on resetting the RF channel and/or ID code of the mouse? There is a small chance that the channels/codes between the mouse and the transceiver were scrambled and you may need to sync them again.
Hope one of these helps!
Posted on Jul 27, 2008
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Hallo i can not get my new wireless mouse to work
Make sure the mouse batteries are fully charged.
Also make sure the mouse is not too far away from the base / cradle and there is nothing blocking the sensor on the front of the mouse cradle.
Make sure all the cables are fully inserted. Check both ends of the power adapter plug going into the back of the mouse cradle and the plugs leading to the back of the computer.
Try cleaning the little red LED light under the mouse with a QTip to remove any dust.
Make sure you restart your computer with the mouse cradle / base plugged into the mouse port.
Then be sure to connect the base and the mouse by pushing the button on the base unit, then the small button on the underside of the wireless mouse.
Also try using a different mouse pad. Some work better than others with certain brands of wireless mice. And also make sure there is not another wireless mouse being used in close proximity. The two can often interfere with each other.
Thank you and good luck.
May 22, 2011 | Saitek PM45p Wireless Notebook Optical...
It's not working!
Make sure all the cords (power and data) from the base unit all securely plugged in.
Make sure you have pressed the CONNECT button on the base and the mouse to initiate the connection.
Make sure the mouse is not too far away from the base when it is being used.
Make sure the LED underneath the mouse is clean of dust or debris.
Make sure the light path bewtween the mouse and the base is not blocked by any object.
Make sure the batteries are fully charged, replace with new ones if necessary.
Make sure there are no other wireless mice in the immediate area which may cause interference.
If all this still doesn't work, try reinstaling the driver and restarting the computer after it is installed.
Good luck.
Mar 06, 2011 | Logitech Cordless Mouse
I have a logitech wireless mouse and keyboard (7 months old)- I recently moved my computer and when I hooked verythign back up it no longer works- I have tried everything from restarting, plugging the...
Underneath the mouse and the keyboard will be buttons labeled "Connect", you will need to resync with the receiver plugged into your computer. Press the connect button on each device in turn and it will attempt to resync.
If this does not work the next thing is to test with fresh batteries, however it is unlikely that both the keyboard and the mouse would run out at the same time.
Finally try with the receiver right next to the keyboard/mouse, sometimes other devices can interfere with wireless signals (WiFi networks, microwaves, vacuum cleaners etc...).
Feb 28, 2011 | Logitech Cordless EX 100 Mouse
Programing
Hi!
First install the driver for your wireless keyboard. Then connect the USB for your wireless. Make sure that you already have batteries in your keyboard and mouse or in other cases fully charged if rechargeable. Wait for it to be detected by windows. Once detected, on the USB press the connect button then followed by the connect button on the keyboard then the connect button on the mouse. Then that is supposed to work already. Hope this helps.
May 02, 2010 | Microsoft Wireless Desktop Elite...
How do I install/begin using wireless mouse? It worked before then batteries ran out and I can't remember if I need a disc to re-install.
Most Logitech wireless mouse are just Plug-n-Play and it does not require any driver installation. All you have to do is to plug the wireless dongle to the computer and connect the mouse. Here's what you need to do:
1. Make sure that the batteries are fresh or fully charged.
2. Turn ON the mouse using the switch button.
3. Locate the connect button on the dongle (receiver) and then press it once.
4. Hold down the connect button underneath the mouse for 5 secs. and then release it. And the mouse should work.
If the mouse is not responding, then hold down the connect button on the dongle and on the mouse at the same time for 5 secs. and then release them both. Move the mouse around.
Hope this helps and have a great day!
Jul 17, 2009 | Logitech Cordless Mouse
I have the Microsoft wireless laser mouse 5000 and it just stoped working on me i was working fine than it just stoped
Make sure that the batteries are good and try pressing the receiver button and then on the bottom of the keyboard press the small button that re-sets and connects the keyboard to the receiver. It then should work properly. Hope this helps. Bud
Jan 07, 2009 | Microsoft Wireless Laser Mouse 5000
Wireless mouse won't work.
Make sure (IF IT CAN BE CHARGED) that it is fully charged then on your mouse there should be button saying CONNECT be sure to click it so it can transmit to the reciever.
Jan 04, 2009 | HP Wireless Optical Mouse
Please help me with my wireless notebook ptical mouse 3000
Alright, so I tried this today and it works. Just a lil of common sense.
First, if you have a new pair of batteries, prepare it. K?
Now get something like a toothpick and go under a light so you can see the inside of the mouse. If you open up the mouse, look inside and see a movement inside it if you hit the thing under the mouse where the connector should go, then that's the switch. There's a small hole to the upper right if you look back inside of the mouse. Stick the toothpick in and push the button all the way up. Keep still like that while using your non dominant hand to put the battery in. ^^
Then let go and the light should be on.
Dec 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I assume this is a wireless mouse, Is there a similar button on the reciever? press this at the same time as pressing the one on your mouse
Mar 06, 2008 | Targus AMU18US Mouse
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
