Question about HP Compaq Presario V2000 Notebook
FREEZING WHEN TRYING TO USE USB PORTS
Hi, my presarioV2000 notebook freezes every time I plug a camera, webcam or flash drive into any of the three USB ports any suggestions?
  • 2 more comments
  • dave76fd Jul 28, 2008
    what should I do about it? Is it an easy fix?
    How do I check if it is setup to accept it?
  • dave76fd Jul 29, 2008
    Another thing i forgot is i have a slot for sd,ms/pro,mmc,sm,xd cards and i can put a memory stick pro in there and it opes fine any suggestions?
  • dave76fd Jul 30, 2008
    How do i disable the card slots?
If These sd,ms/pro,mmc,sm,xd cards is working fine then use these card n forget about other slots. The only way you can do that is take the slot out.
Posted on Jul 31, 2008
    Champion:
  • 258 Answers
USB ports is not configured properly
Posted on Jul 28, 2008
  • 1 more comment
  • Champaklal Patel
    Champaklal Patel Jul 28, 2008
    Check your BIOS. Is it set to accept USB port or not
  • Champaklal Patel
    What you have to do is:
    1 Switch your PC on
    2 Soon as it shows starting keep pressing DEL key (THIS SHOULD TAKE YOU TO BIOS SCREEN)
    WARNING: DO NOT MESS AROUND THE BIOS IF YOU DON'T KNOW ANYTHING ABOUT IT.
  • Champaklal Patel
    Champaklal Patel Jul 30, 2008
    I think that is your problem.These sd,ms/pro,mmc,sm,xd cards might be conflicting with USB DRIVERS.
Sony NSZ-GT1 usb ports not working
You will need to contact Sony support directly to get this issue resolved. Likely the USB port is working, but there is a glitch in the software of the TV that makes it freeze. The fact that it freezes, means the port IS probably WORKING.
Mar 12, 2014 | Sony NSZ-GT1 GOOGLE Internet TV Wi-Fi...
My computer freezes when i plug in external hard drives
Does it freeze when plugging in any USB device? Exam the USB port and plug/cable for any damage. I have seen the pins get bent and the tab cracked on a Dell USB port before.
Sep 02, 2010 | Dell Inspiron 6000 Notebook
My computer freezes when i plug in to the usb with
It sounds like a defect in the USB circuit on your system board. (This assumes that the problem occurs with any USB port). You might be able to add a PCMCIA board to add USB funcionality without replacing the system board to save money.
Apr 25, 2010 | ZT Group Cisnet T2060 Notebook Computer
My laptop freezes when I use USB ports
dell insprion 1525 revision A13 bios password crack
Feb 03, 2010 | Computers & Internet
Freezing while making video
Try connecting to another USB port preferably to the back of pc not through any hub. Uninstall and then reinstall camera driver carefully following procedure in the accompanying manual.
Jul 28, 2009 | Philips SPC610NC Webcam
Pc freezes plugging in usb devices - ipod & memory stick
i have had a similar problem before. if you touch the usb port w/ finger before yopu put in usb device does it still lock up comp. if not there is a grounding problem with port. you computer will not see it ever. check wireing to port and to riser on mother board. or add on pci card.
Jun 24, 2009 | Electronics - Others
The video will freeze and go blank
How much memory do you have installed in your computer. This can be a factor why it freezes up.
You can also try this.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Microsoft LifeCam VX-1000 Webcam
Everytime LifeCam is plugged into USB port computer freezes
Normal 0 How much memory do you have installed in your computer? It may need to be increased as this is likely to be the cause of your computer freezing.
Hope this is of some help. Bud
Sep 01, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Computer locks up when plugged into camera
Might be that the USB Port you're plugging the webcam into is USB1.1 and the camera is USB 2????
look at the port on the computer.. is it Black Plastic or White... If Black It is USB 1 if White...USB2...
Might be that causing the freeze up... Hope it helps
Jun 04, 2008 | Philips SP900N Webcam
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
HP Compaq Presario V2000 Notebook Logo
296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
