Question about Vtech Lands Phones
Unplugged phone to put in new furn. plugged phone in and handset does not answer. It does respond to base.
    Scholar:
  • 108 Answers
Make sure the phone line at the base unit is plugged into the LINE position, otherwise you probably have a wiring issue.
Posted on Jul 27, 2008
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Jul 25, 2011 | Uniden Cordless Phone
One of my cordless phones says not registered. How do I fix that? Also, another phone says check battery. Where can I get another battery? Warranty?
Put the non-registered handset in the master base unit. Unplug the base unit for about 10 seconds and plug it back in. Wait for a message to change on the handset and press and hold the handset locator button for 4 seconds. This will re-register the handset. Do not remove the handset from the base while performing the above steps. Good Luck!
Nov 09, 2010 | AT&T DECT 6.0 Cordless Phone System with...
D51A PD IS DISPLAYED ON MY ATT E2562 HANDSET. ANY
My E2562 handset 1 would not detect base and displayed D51A PD whenever I tried to manually register it. This fixed it:
1. Remove battery from handset.
2. Unplug base and unplug phone connection(s). Wait 30 seconds.
3. Plug in base.
4. Plug in phone connection(s) to base.
5. Put battery back in handset. Handset 1 should then auto register with base.
Mar 15, 2009 | AT&T 2230 Cordless Phone
My handset has a blinking icon, indicating not close to base
I found the 800 number to call, spoke to customer service, they gave me the suggestion of unplugging the base from the outlet, removing the batteries from the handset, wait 5 minutes and plug in and put in the batteries. Yes, that fixed it. And then the customer service technician called back later to see if it had worked. I thought that was above and beyond the call of duty. Certainly a good way to win customers!
Jan 22, 2009 | Panasonic DECT 6.0 Expandable Cordless...
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
No link to base
The solution works!
Thanks.
Feb 15, 2008 | Panasonic KXTG2344 Cordless Phone
AT&T phone model E5634B
SOLUTION to AT&T Cordless Telephone/Answering System 4 phone set Model E5634B - Cannot answer incoming calls nor does caller ID work on phones.
Unplug the base for a few minutes, plug base back in, remove and reinsert the battery on each phone that does not work, then place each handset in the base for few minutes. Worked for me...all 4 phones can be answered and caller ID works!!! Hope this works for you... :o)
Jan 12, 2008 | AT&T E5634B Phone System w/ Caller ID
ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Dec 19, 2007 | AT&T 5840 5.8GHz...
Lands Phones Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
