Question about Sony Audio Players & Recorders
Sony mhc-gx99 mini hi-fi - Does not read the cd.
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Posted on Oct 24, 2008
  • 133 Answers
SOURCE: My sony MHC-GX99 stereo will not play my cds.
Some possible causes:
a) dusty laser lens - cleaning it is the solution, you may use the lens cleaner disc (the one that uses liquid), this can be purchased in many shops. I prefer to clean the lens manually, using a cotton stick and some ethyl or isopropyl alcohol (DO NOT use acetone, benzene or similar strong solvents, these will ruin the lens).
b) dirty brush contacts inside the spindle motor (i repaired quite some CD players that had this kind of trouble). They cause the motor to spin with less power so the driver tries to compensate putting more power into the motor, which causes a feedback effect on focus (it may not work properly). The best solution for this is to replace the spindle motor (if you can find one), the second best solution is to clean the brushes and the commutator (that's what i usually do), but this is a pretty delicate and somewhat complicated procedure since you have to open up the motor, clean it and then put it back together in a correct way. I wouldn't recommend doing this unless there is absolutely no way to obtain a new motor (if you are truly interested in learning how to do it, post me a message, i'll explain it).
c) the main power switch has oxydized contacts, which means that the voltage on the primary of the power transformer is a bit lower, and, consequentially, all of the secondary voltages are lower, too. I know it may sound weird, but i had some players in which i cleaned the lens (on BOTH sides plus the mirror inside the laser), opened and cleaned all of the motors, but they would still not work correctly. Only after i've cleaned the contacts on the main power switch did they return to normal functioning. Obviously it's much easier to change the switch to solve this (if you have a spare one). You can check if the switch is the cause if you bypass it (you need to bring the mains voltage directly to the primary of the power transformer, but do it with caution as mains voltage can be LETHAL to you and your CD player - i don't recommend this either if you're not trained in electric safety).
These are just some of the possible causes. It may as well be that the real cause is something else, so don't take any of these for granted, they are just suggestions.
Anyway, i hope you can fix it (or at least have someone do it for you).
Good luck and best regards
3rq8 (triarcuate)
Posted on Jul 18, 2009
Zlobomir
  • 225 Answers
SOURCE: my sony mini hi fi system.model mhc-nx1.reads ;
Lucky guess: you have an auto-fuse somewhere on the back of the unit.
Posted on Nov 08, 2009
SOURCE: i have a SONY HI FI 'MHC-RG66' mechanical error
kiero saber donde vienen las salidas del estrereo sony mhc rg66
Posted on Feb 20, 2010
SOURCE: Sony MHC GNZ8D Region unlock
Need to unlock the MHC-GNZ8D. Please help.-
Posted on Jul 18, 2010
Sony mini hi-fi system MHCVX33 Audio-VCD, i want to change (Track CD to DVD Mp3 format)
Not possible. DVD to MP3 is a transitional change using a software program like that from Wondershare.
Feb 02, 2015 | Sony Audio Players & Recorders
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD is doing what?
Cd player say no disc when disc is in. (sony mhc-ec691) how to fix
you need a CD head cleaner try Best Buy they usually have one cheap it's a CD with little brushes on it
Dec 31, 2014 | Sony MHC-EC69I Mini Hi-Fi Music Shelf...
Sony MHC-S3 Mini Hi-Fi component system
Correct the laser is not reading the disk. Cleaning won't help. Usually not worth getting repaired as a similar new unit will cost about the same!
May 25, 2014 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
Nov 25, 2009 | Sony Audio Players & Recorders
How can i hook up my Sony Mhc-Gx99 to my pc?
ok ive got one of these leads go to any hifi store or computer store and its a headphone jack with a red and white conetor on the other side there very in price from $5-$20 it depends how long and wat brand if u need ANY more help go and send me a message at mid.nightclub@hotmail.com
Dec 31, 2007 | Sony MHC-GX9900 Shelf System
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
