Question about RCA TruFlat 27F520T 27" TV
Works with dvd but cable it doesn't
My tv works with a dvd cable but when i go to hook up the cable the blue screen appears need help cause im ready to throw it away
    Genius:
  • RCA Master
  • 1,689 Answers
The tuner module or IF module is probably defective, or the section of the power supply or power distribution for these modules has a fault.
The set would have to be checked by an experienced TV tech to determine the area of failure.
Jerry G.
Posted on Jul 30, 2008
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
What do i need to do to make the dvd player appear on screen? help!!
read instruction manual, color out from player to set one at a time===pretty straightforward stuff. inputs on set are labeled so select that input and you should be set.
Sep 03, 2012 | Emerson LC320EMXF 32 in. LCD TV
My dvd player appears to be working - the disk is in place and the numbers advance as if it is playing - but all the tv screen displays is No Signal. I've talked to a Comcast tech and the problem doesn't...
Make sure your TV input source selector is set to the correct option (Video 1, Video 2 or Rear Video Connection or whaever the options are for your TV) when you want to play a DVD.
Try using the DVD player on a different TV to see if the DVD player is working OK.
Then try a different DVD player hooked up to your TV to see if your TV is set up OK.
You can also try using a different set of cables just in case the cables are faulty.
Try using an S-Video cable from your DVD player to your TV (if they both have those connections)and see if you get any signal that way.
When you are testing, be sure to check the sound on your TV to see if you are getting any audio signal from your DVD player.
By carrying out these troubleshooting procedures you should be able to narrow down exactly where the problem is and then fix it.
Apr 19, 2011 | Apex Digital AD-2600 DVD Player
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Sep 09, 2008 | Onkyo TX-SR606 Receiver
No sound, red screen
Sounds like the problem is being caused by bad cables or bad device signal. What is it hooked up to ie; computer, DVD player, etc. Check the cables themselves, start by checking the tips, try to make sure that none of them are bent or tweaked. Let me know what you find, and then we'll go onto step two.
Jun 08, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Component cables not working properly
Make sure to set the "TV Output Select" in the DVR4200's menu to "Component" not "S-Video". **** Page 19 of the manual.
Jan 09, 2008 | GoVideo DVR4200 DVD Player/VCR
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
RCA TruFlat  27F520T 27" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
