Question about Sony Ericsson K800i Cellular Phone
K800i video cannot take a video - as i press to start taking the video it shuts off after 2 secs and goes back to menu screen how do i correct this and it also wont play avi files bluetoothed to my phone...
    Genius:
  • 1,011 Answers
Dear,
i think u have selected the phone memory to store ur vedio and its limited or other case is that:
u have selected the vedio type for mms not for fully vedio. check both options. hope it will cure the problem.
regards,
Posted on Jul 28, 2008
Video goes out on insignia lcd
An lcd tv has to have a light source behind it to see the picture. Older ones have flouresent tubes. Newer set have light emiting diodes(led). You need to determine if the backlight is turning off or is set loosing signal. If you press the menu button on the Insignia remote does the menu appear on the screen. If not hold a flashlight on the front of the screen. if you can slightly see some video the the back light is off. If the menu shows then check the signal source. If back light is out the replace the inverter board.
Jan 07, 2014 | Insignia IS-LCDTV32 32 in. Television
How do you reset your PS3
you hold da power botton n leave it press youll here 1 beap the sec. after it will shut back down. once it shuts down let go of da power botton then 2 once again you press n hold it down youll here da 1st beep sec. after youll here 2 beeps dats when u release it n itll request you 2 plug in the usb n control aswell follow da instruction n it will direct you 2 a menu dat has options of restarting system, tile restoration, rebuild database, ect.
Dec 06, 2011 | Sony Playstation 3 (PS3) Console
On picture taking mode, screen is black but can still take pictures
Please provide more detail about your problem.
Does the screen play back the pictures ok but not during record mode? Or is it off all the time and you used a computer to review the shots that were taken?
Check the basics listed below:
1. The screen may be switched off.
Press the display button on the back while the camera is on. This toggles the display setting between various settings such as Off/ On / Info. Keep pressing the button to try the aternate modes, it just goes round and round to 2 -3 different modes.
2, Check that the monitor brightness setting is set to medium at least in the menu's.
3. If the problem is only affecting recording then check that the main record settings are correct for the type of scene you are taking. For example don't use Beach, Snow, Candle or manual with a high shutter speed while taking regular daylight shots with minimal lighting.
. 4. If the LCD display has a hardware issue you could connect the camera to a TV using the video output jack and look at it that way. Then you'll know if the built-in LCD is ok or not.
5. Having a damaged or stuck video output jack COULD cause this problem also since that circuitry is designed to automatically shut off the built-in LCD display when you connect a video cord to it. Note that having a video cable plugged in to the video output jack would shut off the display also. Such as when you have it connected to a TV.
Aug 12, 2010 | Canon Cameras
Stand by timer shuts tv off after 30 sec sony tv
Sounds more like it's been set to do that. Use the following to shut off the timer mode. It's possible that the set is set to the wrong time of day but that is unlikely. You can shut off the timer mode using the on screen menu. Follow the instructions below.
Using the Timer Menu
Current Time Set your TV to the current day and time. Press to open the Current
Time menu:
1 Use the F or f buttons to enter the correct day and time, then press
2 Press to exit the menu.
Timer 1 and
Timer 2
Scheduled
viewing
Use the timers to program your TV to turn on and off by day, time,
duration, and channel. The timer duration is a maximum of six hours.
When the channel is fixed, it is not necessary to set the channel.
1 Use the F or f buttons to highlight Timer 1 or Timer 2, then press
2 Use the F or f buttons to enter the desired day, start time, duration,
and channel, then press . The timer status should be On when the
Timer has been set, and the timer light on the front panel of the TV
should be on.
3 Press to exit the menu.
? When you perform Auto Program, Timer 1 and Timer 2 settings will be cleared. Also, in the event of
any loss of power, Current Time, Timer 1, and Timer 2 settings will be cleared
Apr 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My son was messing with the buttons on my big screen and now theres a big black box in the middle of the screen.. when i turn up the volume it goes away but when you dont press any buttons it goes back..
well u have that there because... he massed up the menu like in those tv's there is a option if u wana do 2 things at one time like watch the tv and play video game so basicly there is nothing wrong with thee tv.. u have to go through the menu to shut the second screen off.. its probbaly for video 1 or video 2..!! just go through the menu one more time and go on every option u can and u might find it..where it says u wana turn the video screen off
Jan 15, 2009 | Mitsubishi VS-60607 TV
Psp menu problem
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
Hmm... is still not working
Start your computer and tap the F8 key as soon as the computer begins to power-up. Keep tapping until you come to the Safe Mode screen. When the screen alerts you to the fact that you have chosen Safe Mode, click OK.
When you get to the desktop go to the control panel and launch System Properties. Go to Hardware and Device manager. Click the arrow next to the Display Adapter. Point at the adapter, right click and chooser Properties. Click the Driver Tab. Roll back the video driver to previous driver.
If indeed you have installed a new driver that is not compatible with your video card, then rolling it back to the original may very well take care of this problem.
Aug 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Sony Ericsson K800i Cellular Phone Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
