Question about Dell Latitude D600 Notebook
Lap top will not power on
Lap top has been charging since last pm the green light is on that shows battery but will not power on no start up sounds no other lights
  • CarlMendonca Jul 31, 2008
    I have a D600 PC Notebook. Works OK on AC, but the battery display on the "device status lights" blinks red-red-green. It does not seem to be charging, as the unit does not work when I unplug the AC cord. On pressing the battery test button on the battery cover, I get 3 green lights, the outer two and the middle. Help!
    Genius:
  • 2,028 Answers
There are a few things that can cause this. Start by removing the battery and starting on AC only. Then remove the memory and try each chip separately. If these aren't the problem, then I'm afraid the power management system or another component on the motherboard may have failed. You will need to take it in for a professional diagnostics.
Posted on Jul 29, 2008
I have a Dell D600 it will not start up. The light comes on but there is nothing on screen.
Posted on Aug 04, 2008
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
The power light shows on my lap top, but the
You may have a bad battery. Remove the battery and try restarting. If it comes on without the battery, you know that you need to replace the battery.
If that is not the problem, please report any sounds that you hear when you turn on the machine. If you are able to see anything on the screen, please report that too.
Jun 12, 2010 | Acer Aspire 5315 Notebook
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
The last time I used my Compaq Presario v2000 I had it on battery power. The battery died and now that I am trying to use it I have the power adapter plugged into it and I get nothing when I hit the power...
This problem is either due to your power adapter, wall plug or the back of your lap top where the power adapter goes into. My guess would be the power adapter, they are infamous for going bad. Try wiggling the cord that connects to the power brick (black box) from your lap top.
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
Grand-ma knows best
It won't switch on at all, the power light is on at the front and the battery light shows re-charging. But when I press the power button on top nothing happens
Nov 22, 2008 | Toshiba Satellite M35X-S111 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
179 people viewed this question
Alun Cox
