Gigabyte GA890GPAUD3H  AM3 Socket  890GX  ATX Chipset Motherboard Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the three expansion bus slots that are found on the mainboard?
Roy May
Level 3:
Master:
  • Master 435 Answers
  • Posted on Feb 23, 2011
Roy May
Master
Level 3:
Master:
Answers
435
Questions
0
Helped
118058
Points
1332
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16) (Note 4)
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8) (Note 4)
  3. 3 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
(Note 1) Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connector by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When PCIEX8 is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
(Note 5) Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
(Note 6) Available functions in EasyTune may differ by motherboard model.
2answers
HP compaq d530s SFF pci slot1 not worknig
Hi , with the computer powered off and ac power plug removed, press down on power button to discharge any residual energy noting any mainboard mounted LED lights have stopped glowing, then try reseating the " horizontal mounting bracket" ( remove the attached expansion card device ) restart computer , then shut down again , install the expansion card device and restart - hopefully now the pci bus will connect and the card detected and reinstalled by Windows
I need to install d3d in my computer
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Cristina Torres.
Yes you are quite correct a 3D device/graphics/display card needs to be installed in your computer to play games well.
Start by checking what expansion slots are available on your computer mainboard. These are slots going from the front of your computer to the rear of your computer.
There are many different slot types, the most likely would be PCI-Express X16 or AGP X8 or AGP X4. If it is a white slot then it is plain PCI.
Find the model number of your mainboard, it is usually found between the slots and Google specifications to determine the best interface to use.
Then go to your favorite computer store and ask to purchase a graphics card with the interface that fits your computer's mainboard.
Feel free to ask questions.
Take care!
Can you elaborate the functions of this product....
NOTE*
The following applies to motherboards such as an AsRock K7S41GX.
It does NOT apply to motherboards supporting the Intel Core i3, i5, i7, and i9 processors.
1) Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
A) CPU = Central Processing Unit. Another term is Microprocessor, or Processor for short.
The 'Brain' of the computer.
B) Front Side Bus. Also abbreviated as FSB.
The FSB is the 'Information Highway' between the Processor, and the Northbridge chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit ]
C) The motherboard chipset is the Northbridge chip, and the Southbridge chip.
The Northbridge chip handles the faster capabilities of the computer.
It is named NORTHbridge, because on the orientation of the motherboard, it is to the North of the motherboard.
The Southbridge chip handles the slower capabilities of the computer.
D) The Northbridge handles the Processor, Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are high speed graphic technologies.
A graphics card used in a PCI expansion slot, and Integrated Graphics are NOT high speed graphics.
E) The Southbridge handles Integrated Graphics, (OnBoard graphics. Same/same), and the PCI bus.
A graphics card inserted into a PCI expansion slot is one example of Southbridge support.
Any add-in card inserted into a PCI expansion slot, is in the PCI bus.
Therefore handled by the Southbridge chip.
The Southbridge chip also handles IDE (PATA), and SATA harddrives.
Handles USB ports, Ethernet port/s, audio, and the CMOS memory.
F) The Internal Bus is the 'Information Highway' between the Northbridge chip, and the Southbridge chip.
G) The LPC Bus is the 'Information Highway' between the Southbridge chip, and the Super I/O chipset.
The LPC Bus is also the 'Information Highway' between the Southbridge chip, and the BIOS chipset.
H) The Super I/O chipset handles,
Serial port
Parallel port
Floppy Disk Drive
Keyboard
Mouse
2) http://www.asrock.com/mb/overview.asp?Model=K7S41GX
The AsRock K7S41GX has;
A) Socket A processor socket. Also known as Socket 462
http://en.wikipedia.org/wiki/Socket_A
Can use AMD processors that fit in a Socket A processor socket, and have either a 200MegaHertz, 266MHz, or 333MHz FSB.
Here is the CPU Support List,
http://www.asrock.com/mb/cpu.asp?Model=K7S41GX
Supports DDR Sdram ram memory at either 266MHz, or 333MHz.
PC2100 and PC2700, respectively.
Maximum TOTAL Amount of Ram Memory is 2GB
Maximum Amount for EACH ram memory slot is 1GB.
There are two ram memory slots.
Has an AGP (Accelerated Graphics Port) graphics expansion slot, that supports AGP 4X , or AGP 8X graphics cards. (1.5 Volt)
Has two PCI expansion slots
Supports IDE (PATA) harddrive/s. (2 maximum)
Supports IDE optical drives. (CD or DVD, or burners for both)
The motherboard chipset is a SiS 741GX - Northbridge, and the SiS 963L - Southbridge
http://en.wikipedia.org/wiki/Silicon_Integrated_Systems
Regards,
joecoolvette
What are the functions of its parts?
1) Motherboard Diagram, (Proper computer speak for motherboard is Mainboard. I just use Mobo.
MOtherBOard)
2) Soyo SY-KT400 Dragon Ultra - motherboard diagram,
http://techreport.com/articles.x/4139
CPU = Central Processing Unit. Another term is Microprocessor, or simply Processor for short.
The Processor sits in a processor socket.
The processor socket for the Soyo SY-KT400 is a Socket A. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_462
The motherboard chipset is the Northbridge chip, and Southbridge chip.
The motherboard chipset for the Soyo SY-KT400 is the VIA KT400 - Northbridge chip, and the VIA VT8235 - Southbridge chip.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
The Northbridge chip handles the Faster capabilities of the computer.
The Northbridge chip determines what Processors can be supported, what Ram Memory can be supported, and High-Speed graphics.
High-Speed graphics being AGP and PCI Express, not a graphics card installed in a PCI slot, nor Integrated Graphics.
The Processor communicates with the Northbridge chip through the Front Side Bus. (FSB)
Think of the FSB as an 'Information Highway'.
The Northbridge chip communicates TO the Southbridge chip through the Internal Bus.
The Southbridge chip handles the Slower capabilities of the computer.
The Southbridge chip handles IDE, SATA, USB, Ethernet, Integrated Graphics, and the PCI bus.
(As in a graphics card installed in a PCI expansion slot, for one example)
Also handles information from the Super I/O chipset.
The Soyo SY-KT400 - Super I/O chipset is a VIA VT1211
There are 5 PCI slots. All connected to the PCI bus, which is connected to the Super I/O chipset.
Click on this link,
http://techreport.com/articles.x/4139/2
Scroll down a little bit to the photo of the Soyo SY-KT400 motherboard.
A) At the top middle is the Processor socket. White in color, rectangular in shape, square hole in the middle, and socket holes on it.
To the immediate left of the Processor socket are 8 Electrolytic Capacitors in a row.
These capacitors are Radial Aluminum Electrolytic Capacitors. (Used all over the motherboard)
These particular 8 are part of the motherboard voltage regulator circuit.
Specifically, voltage regulation for the Processor.
B) To the right of the Processor socket are three long Black Ram Memory slots. (Proper computer speak for Slot, is Bank. 3 Ram Memory Banks)
C) The Blue and the White connectors to the right of the Ram Memory slots are IDE connectors.
One for the Harddrive, the other one for the optical drive/s.
D) Underneath the Processor is the Northbridge chip. There is a clear fan sitting on it.
E) The large square Black chip with VIA on it, below the Ram Memory slots, and to the right of the purple PCI slots, is the Southbridge chip.
F) The 5 purple long slots are PCI expansion slots.
G) To the right of the bottom purple PCI slot is the CMOS battery.
H) Above the purple PCI slots is a brown AGP slot.
Uses AGP 8X graphics cards
The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
1helpful
What is the advantage of PCIe expansion bus and how willl it contribute to providing a solution at the internet cafe?
A PCI expansion bus is a slot in your computer, a place where yo can plug in a electonic device. There are several different kinds of slots in most desktop or tower style computers, PCI is one of them. PCI slots will accomodate a variety of expansion devices, a modem or Network interface card for example.
How a PCI clot will interface with the rest of your question is a mystery to me. What is the problem at the internet cafe??? I would expect most folks would use a laptop computer at a internet cafe ... laptops do not have PCI slots. The Cafe may have a tower with PCI slots and they may have an issue that could be addressed by an expansion card installed using the PCI card.
If you can ask your question or present your situation, I and other volunteer workers here would be glad to have a look at it.
Thanks for your interest in FixYa.com
2helpful
3answers
Wha t is a pci
Conventional PCI (part of the PCI Local Bus standard and often shortened to PCI) is a computer bus for attaching hardware devices in a computer. These devices can take either the form of an integrated circuit fitted onto the motherboard itself, called a planar device in the PCI specification, or an expansion card that fits into a slot. The name PCI is an initialism formed from Peripheral Component Interconnect. The PCI Local Bus is common in modern PCs, where it has displaced ISA and VESA Local Bus as the standard expansion bus, and it also appears in many other computer types. Despite the availability of faster interfaces such as PCI-X and PCI Express, conventional PCI remains a very common interface.
The PCI specification covers the physical size of the bus (including wire spacing), electrical characteristics, bus timing, and protocols. The specification can be purchased from the PCI Special Interest Group (PCI-SIG).
Typical PCI cards used in PCs include: network cards, sound cards, modems, extra ports such as USB or serial, TV tuner cards and disk controllers. Historically video cards were typically PCI devices, but growing bandwidth requirements soon outgrew the capabilities of PCI. PCI video cards remain available for supporting extra monitors and upgrading PCs that do not have any AGP or PCI Express slots.
Many devices traditionally provided on expansion cards are now commonly integrated onto the motherboard itself, meaning that modern PCs often have no cards fitted. However, PCI is still used for certain specialized cards, although many tasks traditionally performed by expansion cards may now be performed equally well by USB devices.
2answers
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Monitor screen stays blank
HP desktop computer? Change the monitor cable. The cable from the monitor to the computer, may be bad.
Happens.
If this doesn't solve it then I suggest the GPU is bad. Graphics Processing Unit. If you have Integrated Graphics, (Also referred to as 'On-Board'), then I suggest buying an average, inexpensive graphics card, and installing it.
You'll have to see what expansion slot, your computer uses for graphics. It may be a PCI slot, or an AGP slot, or a PCI Express x16 slot.
Clear as mud on that last one? Let me give you some links, that might help clear up what an Expansion slot is, and the three types of expansion slots used for a graphics card.
1.Expansion slot:http://en.wikipedia.org/wiki/Expansion_slot
2.PCI (local bus):http://en.wikipedia.org/wiki/PCI_(bus)
3.AGP:http://en.wikipedia.org/wiki/AGP
4.http://en.wikipedia.org/wiki/PCI_Express
5.http://en.wikipedia.org/wiki/File:Asus_a8n_VMCSM02.jpg
The link above (No.5) shows a photo of an average motherboard. At the top right you will see two White slots. Those are PCI expansion slots.
Below the PCI slots is a PCI Express x16 slot. It is Black in color.
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
