Question about LaCie (300770) 250 GB Hard Drive
175gb missing from 250GB hard drive
Hi.
I installed a 250GB hard drive on my xp system. Made 2 partitions 118gb + 115GB. Life was good for some time until all of a sudden 75GB go missing from partition one and 100GB missing from partition 2! I reformatted partition 2 but still the same problem. It shows total space= 115GB, Free space= 9.9 GB. The only folders visible after the reformat are System Volume Info and Recycler. I ran SpaceMonger which shows me the free space but then says that 100GB are "unscannable".
Any assistance would be much appreciated. Thanks.
    Brigadier General:
  • 6,966 Answers
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 28, 2008
  • Louie  Role
    Louie Role Jul 28, 2008
    Hi again,
    if I may add, when re-partitioning has been done, to prevent recurrence of the same, you may want to lesses or altogether disable "System Restore".
    Cheers.
Is it possible to partion System drive.?
If your C drive take up all the 250GB, and the used data is not up to 250 GB( I means there are some free space on your c drive) you could use other partition software to release some free space ( resize partition) then create new partition, with the help of partition software, it could apply the operation without re install OS.
Oct 23, 2012 | Microsoft Windows XP Professional SP3 Full...
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
Wd 250gb laptop HD only shows 118gb
In XP Start > Control Panel > Administrative tools > Computer manager then on the left click disk managment, you will see your 250gb drive as drive0 most likly with partition C and beside it you should see unallocated space, you can right click this unallocated space and format it, then right click again and click make partition active.
Jun 20, 2010 | Western Digital 250GB MyBook External USB...
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
Had vista, now XP
Hello
Ok, at the link below you will be able to download all the chipset drivers. Just click on the loink, you will be directed to the dwnload page.
http://www.getpcmemory.com/drivers/download-toshiba-satellite-pro-l300-notebook-windows-xp-drivers/
Kind regards
Andrea
Jan 24, 2010 | Toshiba Satellite Pro L300 Notebook
How do I install windows XP on Compaq CQ40 327TU laptop
Try downloading Hiren Boot CD and run you can resize the Harddisk accordingly.
Mar 31, 2009 | Computers & Internet
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
3 partitions missing on a 250gb SATA hard disk
i think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Jul 09, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
LaCie (300770) 250 GB Hard Drive Logo
265 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
