SAFE MODE:
1.
Place you
finger on the on/off sensor leave it their until you console turns off then
take you finger off the sensor.
2.
Place your finger back on the on/off sensor
leave it their until you hear 2 consecutive beeps then take your finger off.
3.
Once the safe mode screen comes on select the
option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all
data except the OS. I recommend backing
up your console onto a USB flash drive if possible.
Good Luck!
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
