Question about Nikon Coolpix 4600 Digital Camera
Taking pictures My camera takes a long time taking pictures and flashes two times. It also takes a long time to sitch back to the main screen after taking the picture. The screen turns black for about a minute then switches back to the original screen. It also has a red hand on the right side of the screen and alot of the pictures are blurry.
  • linda430 Nov 15, 2008
    I have a Coolpix 4600. When I take a picture, it takes so long that sometimes the subject (such as a dog!) has already moved. I have a SanDisk 512mb. Someone said I need a faster memory card. Any ideas?
    thanks!
  • richjl4 Nov 29, 2008
    Our camera after taking a picture takes an awful long time to set itself up to take another picture.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
Posted on Jul 28, 2008
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
HI, I have nikon L110 and when i click pictures without flash in portrait mode and auto mode it takes long time to display on screen after clicking the pictures .. but when i use flash it comes quickly ....
It takes the same amount of time after the picture is taken for it to appear on the screen. Without flash there's less light and the camera requires more time to collect enough light and take the picture.
Dec 15, 2010 | Nikon Coolpix L110 Digital Camera
Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Apr 26, 2010 | HP Photosmart R927 Digital Camera
When using flash it flashes multiple times when taking picture..strobe flash
Hello
You will find that if the flash pulses slowly several times before taking the main picture you have got the camera set to red eye reduction flash, you will see an eye symbol on the display.
Check the owners manual for the method of changing this to the setting you need.
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part2.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part3.pdf
Above are the links to download the owners manual for this camera.
Hope this helps
Sep 25, 2008 | Minolta Maxxum 400si 35mm SLR Camera
After reseting the dsc w50, becouse of e .91.01., flash is not working
hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Aug 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
How do i reset my camera
After selecting flash off mode the camera determine the shutter speed according to the available light which may be rather slow.Therefore either camera shakes or the object or may be both of them while taking pictures.That's why pictures are blurry. Keep camera steady or mount it on a tripod while taking pictures on flash off mode. Once u set the date & time and select OK I think it will not bother u again.
Aug 22, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Takes forever to take multiple pictures
My camera has different "modes" and if I put it in the "action" mode it seems to work more quickly between pics. There should also be a setting to change how long the pictures is displayed after taking, if you shorten that it will recover quicker to allow the next picture taking.
Jun 08, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
141 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
