Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Canon imageclass mf6530
The copier was working fine and then if started printing blank pages
the toner is new this is the second or third time it has happened the last time I was able to turn it off and on and it started working again this time it will not work.
Thanks!!
  • Icontech Nov 06, 2008
    My printer was working ok, and started to print blank pages, from the scanner, the printer or when printing from the pc.
    tried a good known toner cartridge, with no changes.
    hope you can help
  • 4 Answers
Reason : the shutter of the laser is not opened by the cartridge. (I had same problem, and solved it)
Open the door and remove the toner. look inside and you will see in the upper part a rectangular window in the metal bar. This window is shut by a metal plate behind when the door is open. Try to raise it with a knife. This is the problem. Now, this shutter is here only for legal reasons (security to prevent the laser beam going out when door open, but when the door is opened the power is shut so...). Cut a piece of plastic just the width of the opening, fold it at angle in the form or an L, then place it on the left side of the opening, so that the shutter can no longer go down. A piece of scotch to fix it in place and you are done.
Now, if it works and you are grateful, I am interested in empty cartridges.If you have some tell me. Thanks.
Posted on Dec 16, 2008
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MF6530, intermittent blank copies using ADF
Its an laser shuter problems, you can say its factory error, if its under varanty call service to fix it
Feb 11, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Copied pages come out blank. I've replaced the toner cartriage with the same results
have worked on copiers 25 years these machines have a laser shutter which will stick after toner cart replacement
Oct 18, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Copier prints out blank paper
its is a bad, stuck laser shutter. It needs replaced with updated one. You could rip out the shutter but it is agaist the law to remove the safety feature.
Jun 20, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass MF6530
try ( add.function & #) service mode and then find clear all
Feb 26, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon MF6530 spits out blank pages
Worn Laser Shutter Arm. Part number FC6-7331. The laser door is staying closed instead of opening to write to the drum.
Jun 24, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
203 people viewed this question
old marine
old marine
