Question about Hotpoint RGB790SEHSA Gas Kitchen Range
Hotpoint RGB745BEA3AD Stove-Ignitor?
Dear Sirs,
Our Hotpoint range (oven) sometimes does not light off. The top range works fine, but the oven sometimes does not light? When it does work it works fine. Is this an ignitor,gas valve or thermostat problem? Thanks Frank.
fridgetech
  • 473 Answers
SOURCE: Hotpoint gas oven
Most common problem is the ignitor.
Posted on Jul 14, 2008
garing
  • 998 Answers
SOURCE: Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 16, 2009
Bat1956
  • 585 Answers
SOURCE: Just changed the oven ignitor switch..switch comes
Given what you have said in the question, I would have to say it is to stay on.
Posted on Nov 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: hotpoint gas oven - temperature varies during
The ignitor is too weak. Replace it.
Posted on Dec 23, 2009
  • 110 Answers
SOURCE: old hotpoint gas stove. burners and broiler work
Usually ranges have a pilot at the bottom. Take the bottom panel off and there should be a button that says 'pilot' hold the button down for a few seconds to let the air purge out. Then while still holding the button down, light the pilot with a match or a lighter of some sort. Continue holding the button down for a few more seconds until the thermocouple has warmed up. (You'll know the thermocouple has warmed up if you can release the pilot button and the pilot stays lit)
Posted on Mar 11, 2010
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Hotpoint Ovens
Gas oven, broiler and stove top work, but bake does not
heatman101
Nov 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Hello the bottom of my stove doesn t light i
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 29, 2010 | Hotpoint RGB745 Gas Kitchen Range
I have a Hotpoint RGB745 gas range everything works on the stove except for the oven. It now will not come on. the ignitor glows but will not light and if it does the oven will go out. the broiler works...
The ignitor gets weak and dim and does not allow for the safety device to open and let the gas flow. The igniter must pull at least 3.2 amps. I have a short video HERE
Dec 31, 2009 | Frigidare FED300E Electric Range
Oven burner won't light
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Apr 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Hotpoint RGB790SEHSA Gas Kitchen Range Logo
123 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
