Question about Raymarine E120 Multifunction GPS Receiver
Raymarine e series malfunction
Network includes e120 and e80, open array radar and 600kw transom mount ducer.
multiple intermitent problems include "no fix", "no scanner", and "no signal" for the charplotter, radar and sonar, respectively. just had the entire system re-wired by reputable local marine electroncs company. did not solve the problem. of course everythin worked ok when they were there.
  • w226 Oct 20, 2008
    My E80 blacks out sometimes. It can be just a flicker or the screen blacks out for several seconds. Only once did all the keys quit working including the power button and the screen rebooted itself repeatedly. The cable had to be disconnected before I could shut off the E80. It was working perfectly again the next day.
  • 43 Answers
1. Both plotter must have the same software 5.23
2. the plotter were the Radarkabel is connected shoud be you MASTER
and the other with no Radarconection SLAVE.
Posted on Oct 22, 2009
    Scholar:
  • 76 Answers
I have found that many of the issues you are experiencing are a result of operator error (no offense). For the system you have described, you will definitely have a network switch which interfaces everything. Is it possible that the network switch is powered from a source that you dont always turn on? In other words, if the system has multiple breakers and the network sw is tied to one of them, using only one display for example may leave the switch without power and give the error messages you described. Bottom line......BE SURE that the entire system is powered on. Another possible cause is master vs slave. One of the two displays is the master. If you power the system up in the wrong order or without the network switch in the loop, the slave unit will automatically ask you to set it as the master. NEVER do this. Changing the master will result in data loss as you described. Finally, if all of this checks out, verify the software in your displays (the version will appear in the bottom right during start up). Your software should be at least V4.29 but there is a newer version available so if you need to upgrade make sure you get the most recent. Good luck
Posted on Sep 13, 2009
Even after double checks on settings Iam still getting weak echos on Raymarine E120 radar. On higher ranges picture is non existant. Where could my problem be?
How old is the radar antenna? When the echos are weak that is a sign of a failing or weak magnetron. Have you gone into the system diagnostics page to read what the signal strength of the radar is?
Jun 11, 2010 | Raymarine C120 System Pack C120 Raystar...
Raymarine "DSM connection lost"
Murray,
Has the DSM and the E120 software been upgraded to the latest software: 4.12 for the DSM and 5.52 for the E120?
Try this first. You can download the software off Raymarine.com and burn each to a separate compact flash card.
I have seen many problems like you are experiencing solved with this simple change.
If this doesn't solve the problem, the DSM will have to go back to Raymarine for repair.
Apr 19, 2010 | Raymarine Dsm30 Digital Sounder Module
Connect an raymarine E120 Display to the RNS software in a PC
Try a cross over network cable from the PC to the E-Series. Raymarine Made each one of their cables as a straight cable so you would need to buy the cross over coupler or network switch box to use it with another unit. It's nothing different from normal networking with the exception that they have removed wires 4,5,7 & 8 from the cable and it's a straight. Give that a try.
Mar 21, 2010 | Raymarine E120 Multifunction GPS Receiver
With the VHF on I can here the signal coming from the transponder, The orange indicator light soon changes to green pulsing gently. The E80 display unit displays ''No Data Source'' yet when the...
I would recommend upgrading the E80 and the DSM to the newest software levels:
E80 - 5.52
DSM - 4.12.
You can download the software off raymarine.com and load them onto different compact flash cards. Both softwares are upgraded through the E80 display.
Jan 29, 2010 | Raymarine St60 Plus Package, Includes...
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
Loosing GPS signal on a E120, also have 2-E80's on same boat, and they too loose signal
1. All your E Series MUST HAVE the same Software 5.23
2 You must set the Divice where the GPS Signal comes in as MASTER
all the other Repeater
3. Your GPS antena shoud be mounted outside
Sep 16, 2009 | Raymarine E120 GPS Receiver
Raymarine a65 transducer 200kh fine 50kh not reading bottom
First do a factory reset and determine that all the setting are correct. You can get this info from the manual. Remember you will loose any saved way points when you do the reset. If that does not sort you out;Remove transducer from transom mount and duck tape it to a broom stick so that the transducer face is facing down. With the boat standing still in calm water and the ducer hooked to the DSM25 push it below the water and see if it see bottom on 50khz.The idea here is to get the ducer in another location to see that it is not getting reflections of the boat. 50Khz is very prone to reflecting of stuff around it. If you still have a problem I would send the ducer and DSM25 unit back under warrant .No need to send A65 back it should not have a problem.
Mar 30, 2009 | Raymarine A65 Combo GPS...
I have a Raymarine E80 interfaced with an AIS. The port setting for the AIS is required to be 38400. If I switch the AIS on - it makes the E80 reboot after about an hour - and the system loses its...
The software shoud be 5.23 for the E 80
If you have two E series maybe a E 80 and a E120 both MUST HAVE the same SOFTWARE
If not you can have problems like this.
Mar 01, 2009 | Raymarine C80 GPS Receiver
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
Master vs. repeater confusion
The master/repeater selection is for the purpose of determining which display is in control of the waypoint and route database.
Turn on both units and let them boot up. Do not answer the master/repeater question until both are on. Then press "Set as master" on the preferred one.
The units remember individually if they were set as a master or repeater the last time they were on. If they are powering up to find themselves in a different configuration than they were previously in, that will prompt the whole master/repeater thing to happen.
Sep 18, 2007 | Raymarine E120 GPS Receiver
Raymarine E120 Multifunction GPS Receiver Logo
630 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
