Question about Kenwood ProTalk TK-3102 (4 Channels) 2-Way Radio
Stoped working i have 2 Kenwood ProTalk TK-3102 2 radios and one is not workng when you press the button to talk it makes a beep or ringing noise and just started doing it out of the blue and the red light is flashing
  • eliminator33 Aug 01, 2008
    thanks for the infor ... so this can happen out of he blue @ random ??
  • 47 Answers
Reprogram the radio, it sounds like it has corupted software
Posted on Jul 31, 2008
  • proff 128
    proff 128 Aug 01, 2008
    normally cause by dropping or the flash RAM loosing the programmed frequency. Did you program the radio with its frequencies. If yes, the program lead was removed before it was completed. to fix it remove the covers , some where you will find a Reset land on the circuit board, short that to ground , then reprogram the radio
When I turn it on, why does it indicate confirm?
Something is wrong with the programming. It does not happen often, but it happens. Reprogram it, or find the factory reset in the manual. If that does not work, the radio memory chip is defective. Reset is your best option.
Aug 28, 2015 | Kenwood Tk 3300 Protalk Uhf Two Way Radio...
Kenwood Protalk tk-3200U8P will receive, but not transmit. When talk button is push a loud beep will sound. Any suggestions?
Assuming it is programmed correctly, it is a weak, undercharged or bad battery. Transmit takes a lot more power than receive. A beep or no transmit, even if the Transmit light comes on can still mean the battery condition described.
Feb 11, 2015 | Kenwood Radio Communications
Kenwood tk-3301
Here's a link to the user manual - http://images.kenwood.eu/files/prod/1567/5/TK-3301_Instruction_Manual_B62-2154-20.pdf
I did a quick scan and could not find the answer in it, but it does give a lot of information about programming the radio.
Apr 22, 2014 | Kenwood Protalk XLS TK-3130 (2 Channels)...
Operating frequency
make sure they are on the same channels, and all settings match, then buy them each a cosmo and give them some time together in private
Sep 17, 2013 | Kenwood Protalk XLS TK-3130 (2 Channels)...
I have a tk-250 I can receive calls but cant transmit when I go to talk and all it does it beeps what do I do
You may have the "tx offset" turned on and may be trying to transmit on a frequency that is considered "out of band" for the radio. Or the frequency you're attempting to transmit on is simply out of band for that radio. It depends on where in the world you're using the radio. If it was a Euro or Japan radio and you're in the US or South America, the bands are different.
Sep 16, 2013 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
I can't hear the other radio on the kenwood ProTalk XLS
DQT - "Digital Quiet Talk" You have inadvertently turned on "digital squelch". Turn it off and you'll hear again.
Apr 17, 2013 | Kenwood ProTalk XLS TK-3230 Business Two...
My new kenwood protalk tk 3130 wont talk to me old 3130
Look at the user manuals for both radios and compare the frequency assignment for each channel. find the ones that match and program the radios to talk to each other.
Patrick
Nov 18, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Keewood Protalk 2 way radio xls receives , but doesn't transmit
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Keylock
Hin, On most new models of Kenwood two-way radios, the user can lock the MENU and up/down buttons. To lock/unlock, press on the menu button (a second or 2) until you hear a beep or till the lock icon in the display appear/disappear. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 04, 2007 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Radio Communications Logo
342 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
