Question about GE DBSR453EBWW Electric Dryer
Ge dryer model# dvl223
Was working fine just stopped working on a dime wont start, bought new dryer it wont start either. bought new breaker 30 amp for elec. pole old breaker still good. help me please
    Problem Solver:
  • 8 Answers
This may sound silly but did you check (or have the means to check) for voltage at the outlet? The absolute bottom line is that if there is no power.......you get the rest.
Posted on Jul 28, 2008
Why wont the top 30 amp breaker won't reset?
YES!
New breaker is cheaper than a service call and quicker than tearing the dryer apart.
Jul 10, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
My dryer runs and drys but after a little while it will trip the breaker in the electrical panel. Anyone have a clue? It's a GE mod.# DLLLR23EG1WW. Thanks in advance for any help. Tom
Hello, W/D here.
When a machine is operating properly, but then trips the breaker, the breaker itself seems to be suspect. Breakers wear over time, and can become "weak". Also, amps on a breaker are time weighted. The more amps that you pull, the less time it takes for the breaker to trip. This is also true with a weak breaker. Check the amps that you should pull with your dryer, and check the breaker. If the breaker is the correct size, try replacing it. You should be on a 30 amp breaker/circuit.
Here are some useful links for your dryer:
Owner's manual http://www.managemylife.com/mmh/owner_manuals/6276/GE-Residential-Dryer-L0707113?brand_name_search=DLLLR23EG1WW+GE Installation guide accessible from same link.
Parts manual http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DLLLR23EG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DLLLR23EG1WW
Best regards, --W/D--
Apr 07, 2011 | Dryers
Model DVL223 GE dryer buzzes / hums when the start button is turned, but does not start or turn the tumbler tumbler moves freely by hand from inside
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | GE DVL223EBWW Electric Dryer
Dryer stops
Unplug your dryer plug. Go to your house electric panel, turn off your 30 amp dryer breaker, and then turn it back on. This resets the breaker. So before opening up the dryer to look for fuses, make sure you have power at the receptacle. Don't plug anything into the receptacle until you have wired it correctly. If you want to run it by me when you're wiring it, that's fine with me. . I hope this helps. Good Luck! Jim
Mar 16, 2010 | GE DBSR453EBWW Electric Dryer
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
GE DBSR453EBWW Electric Dryer Logo
174 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
