Question about Samsung Refrigerators
Our Samsung fridge freezer is leaking water at the bottom of the freezer, which is turning to ice and also leaking out onto the floor. It has also started doing a clicking sound from the same area. Help please!
  • hobbabrennan Jul 28, 2008
    Thank you very much for this Mr Durland, I will give that a try.
  • 481 Answers
The water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 27, 2008
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Fridge freezer leaks water from bottom
your drain for your evap is clogged...... need to clear drain of ice then will be ok. brand and model # would be helpful.
Jan 03, 2012 | Refrigerators
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Jan 09, 2009 | GE Profile PFS22 33" Artica French Door...
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
206 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
