Question about Dell 924 All-in-One InkJet Printer
Error message 1203
I keep getting Error Message 1203 on my Dell All-in-One 924 Ink Jet printer. It refers you to the Owner's manual, which is no help. It only says to reinstall cartridges, disconnect/reconnect power, which I tried several times. I also tried cleaning the contacts with rubbing alcohol. And I just installed a new black cartridge. Only difference any of this made is that the 1203 message changed from "print head short" to "cartridge error". I don't want to waste more money by replacing the color cartridge too, if that's not going to fix the problem. Anybody have any suggestions?
  • sun prairie Aug 01, 2008
    Problem solved. I took my printer to Office Max, described what I
    had done so far, and told them that if a replacement color cartridge
    would resolve the problem I would gladly buy it- I just did not want to
    spend the money on a new color cartridge for a dead printer. We
    installed the new cartridge there in the store, tested it out, and
    everything is now fine.
    Problem Solver:
  • 13 Answers
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Posted on Aug 01, 2008
    Novelist:
    Champion:
  • 256 Answers
1203 is mainly arising due to the issue in the cartridge. The error code 1203 mainly refers to a cartridge. The issues with the cartridge might prevent the printer from functioning. The printer could not carry out the printing activity or ink might not get fall correctly into the paper. The cartridge might face with some technical issues. Due to all of these issues, the printer could not work properly and the error code 1203 might appear in the screen.
Posted on May 24, 2011
Get error message 1203
Hello.
That error is cartridge-related.
Check to see if ink is smeared on the holder where it contacts the cartridge.
Use a damp tissue and clean the cartridge contacts.
Then, align the cartridges and run the printer cartridge cleaner a few times.
Hope this helps.
Nov 23, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
My dell printer 924 is giving me a message 1203
From what I was reading this error is caused by the contacts where your print cartridge connects being dirty or having old ink smeared on them. Pull out your ink cartridges and use a cloth with just a little dab of water to wipe any old ink off of these contacts.
To reset the error code you should be able to disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Apr 10, 2009 | Dell 924 All-in-One InkJet Printer
Trying to insert new ink catridges
I think it will do the trick for you try this.
or
Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203
Seen this lots with dell printers.
or
Mar 24, 2009 | Dell 924 All-in-One InkJet Printer
Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
I am getting a message error 1203
Try this first see if it will help.
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Dell Printer 924
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Jul 14, 2008 | Dell 922 All-In-One InkJet Printer
HELP!!!
what i did was remove the color cartridge then close up the printer. it then gave a missing cartridge error but you can click through that so you can run with one cartridge. then everything worked fine and so i went back and put the color back in and it was good to go
Apr 26, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
1,045 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
