Question about Lexmark X5470 All-In-One InkJet Printer
Scan application cannot retreive scan application lexmark 5400
  • redgoona1 Nov 29, 2008
    hi i have the same problem with my x 5430 have been in contact with lexmark 6 times on the phone and 3 times by email and the still have not called me back to finalise the problem.they have tried to remove the software 4 times and reload downloaded software,but i'm still not able to use this A4 paper stacker.
  • foluogun Dec 30, 2008
    I think i have the same problem whenever i push the scan button it says retrieving application list but then its says it cannot retieve the list? what is wrong?
SANURULZ YOU ARE A CHAMPION WORKED WELL ,I OWE YOU BIGTIME.IF YOU EVER COME TO AUSTRALIA I WILL TAKE YOU OUT ALL NIGHT. 7 LEXMARK TECHY'S AND 2 HIGHER RANKED TECHY'S COULD NOT FIX THIS IN 8 WEEKS.
Posted on Jan 15, 2009
  • Lexmark Master
  • 684 Answers
Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Brose My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
4 Suggested Answers
SOURCE: I got Lexmark X5470 a month ago..
I got help directly from here, It worked for my
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=227:5:0:597:0:0&framed=&docid=ENUS28866&relevance=1
RAF Dell M65 Precision Vista Ultimate
Posted on Feb 08, 2008
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Posted on Jul 07, 2010
alpug
  • 1961 Answers
SOURCE: I want to scan a
A problem occurs with your scan driver. You will need to reinstall it to correct the problem.
Another way to scan is to use the scanner option in your computer. Go to Control Panel. Double click the Scanners & Cameras icon. Feed your documents in the printer before starting the scan process.
Try it.
Please give this answer a four thumbs up rating it this help you.
Thank you for using Fixya
Posted on Sep 12, 2010
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
Cannot retreive application list
Please try scanning using Paint:
1- Click Start (If you have Windows XP, Click Start and then Click Run)
2- Then type "paint" without the quotes into the search box and press ENTER
3- Click File, and select "From Scanner or Camera"
4- Make any changes you would like and click "Scan"
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 16, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cannot retrieve applications listo lexmark 3500
my printer will not scan when i try it tells me downloading applications list then it will not download it tells me cannot retreive applications lists and i have reinstalled the disc and still nothing
Jan 27, 2010 | Lexmark X5470 All-In-One InkJet Printer
Have a Lexmark X5470; when 'Scan Mode' is engaged,
on your computer: click on start all programs / programs check for the lexmark folder ( lexmark 5400 Series ) check if there is any application under it ( AIOC , Productivity Studio, or Imaging Studio ) If there is: check your firewall, this might be blocking the application list. If there's none: Using the disc: Start My Computer / Computer Open your CD/DVD drive where the lexmark disc is Open application folder Run Setup under application folder. This should update the software
Mar 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series all-in-one fax printer scanner copier
This is not so much a solution, but I have a lexmark 5400 printer -and I am also having problems with "alignment." I just replaced the cartridges an now I am getting an error message saying: "Alignment problem, remove tape from cartridges, check paper and then press the check-mark button." There does not appear to be anything wrong with the cartridges (there shouldn't be - they're new), but the cartridges will not center when the cover is lifted. So I can no longer print anything, and I can't check the cartridges - help!
Any information anyone can provide would be greatly appreciated. I'd hate to replace the printer, it's still in very good shape.
Thanks
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
