Question about Kenmore 98702 Stacked Washer/Dryer
Need help asap, please!
Runs for 20 sec then stops and it won't cut in for about 5 mins then it shuts off 20 sec later. Plus there is a light smell of smoke. 1. Whats the problem? 2. How do i fix it. Oh it's the washer I'm talking about.
Thanks.
  • Da_Joker82 Jul 27, 2008
    Thanks for the help.
I tried switching to the spin cycle. It worked for about 20-30 sec then shut off. I tried to switch it back on. It doesn't switch back on right away. It is as if it has to cool down. Does this still sound like a timer issue? Also, does the motor go by any other name?
Posted on Jul 27, 2008
  • 868 Answers
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Dryer starts for 10 sec and then stops, has an burn smell it runs great Although when it stops it won't restart until a few mins later. Then the same over again. Its a loud noise when going for 10 sec
It sounds like it's overheating.
Find and clean the filter.
The noise might be something caught between the drum and the mechanism. A bra underwire is common if your female (anonymous)?)
Check with a good torch...
If you rotate the drum and it squeaks it's something jammed or maybe the bearing.
Apr 20, 2016 | Dryers
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
I just bought a used mtd sprinto. The previous owner seemed very genuine and said he hadn't used it for a while (a few months, I think). The mower is very clean all over and looks in good condition. The...
If there is an anti fire solinoid on the base of the float bowl you need to check it functions ok, unscrew it from the float bowl, switch the ignition on, the centre pin should retract fully into its housing, if not it will shut off the main jet in the carb and cause all sorts of problems.
Aug 10, 2013 | Mtd Garden
99 neon: random misfire-error code 43-runs choppy-poor gas mileage
No Engine I know of has a 1,2,3,4, fitting I am sure you have the firing order connected wrong, plus your description point to the firing order as well. Cheers, Malcolm Campbell.
Apr 18, 2017 | 1999 Plymouth Neon
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
May 07, 2017 | 1997 Mercury Cougar XR7
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Oct 06, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
89 regal won,t start but after 5 or 10 min. runs great
sounds like your fuel pump is going out. One thought might be that the fuel filter is causing enough resistance to over heat the pump. I would check the fule pressure to determine a free flow of fuel.
May 01, 2009 | 1990 Buick Reatta
My avenger cuts off after being driven for at least 5-30 minutes
a very common problem with these cars is the crankshaft position sensor. also camshaft position sensor. they will make the car do exactly what you described. let me know what you find
Jan 06, 2009 | 1995 Dodge Avenger
Kenmore 98702 Stacked Washer keeps stopping, and a smell of smoke.
More than likely there is something locking up your motor. Either the transmission or the drain pump, both are connected to the motor. The easiest way is to disconnect the components from the motor to determine which one is causing the problem. Most of the time it is from the something being lodged in the pump, a sock, screw, wire, etc. To get to the pump you need to tip the washer back far enough to get underneath the washer.
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
