Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer keeps stopping, and a smell of smoke.
Runs for 20 sec then stops and it won't cut in for about 5 mins then it shuts off 20 sec later. Plus there is a light smell of smoke. 1. Whats the problem? 2. How do i fix it. Oh it's the washer I'm talking about.
Thanks.
  • Anonymous Jul 29, 2008
    same probelm
  • 100 Answers
More than likely there is something locking up your motor. Either the transmission or the drain pump, both are connected to the motor. The easiest way is to disconnect the components from the motor to determine which one is causing the problem. Most of the time it is from the something being lodged in the pump, a sock, screw, wire, etc. To get to the pump you need to tip the washer back far enough to get underneath the washer.
Posted on Jul 29, 2008
I have the problem it stops befor and won't drain or go in to spin is there a reset button
the pump is plugged up with foreign material and shutting down the unit,remove rear cover or lower front cover to access the pump and remove hoses to clean it out
May 02, 2012 | Kenmore 98702 Stacked Washer/Dryer
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer
make sure you have good air flow out the house if you do go ahead and change your thermostats and your high limit thermal switch.
Apr 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
