Question about Toshiba Televison & Video
43vj13p no pic or sound menue active no blue screen after several hours coms on
    Problem Solver:
  • 3 Answers
Painter ic on teletext board solution remove text modual
Posted on Jul 29, 2008
My Mitsubishi vs-60603 projection tv has only a blue screen but I have sound. When I go to menu, the picture is in upper corner but picture is only blue when not in menu
Lol sounds like you tripped the pic in pic option.. the blue screen would probably be the feed from dvd or one of the other input options . Good luck I did that years ago and it took me forever to get out off... and a case of beer later... I think it had something to do with the pvc button on the remote.... stands for preview channel. so you could watch one and keep an eye on the other
Oct 16, 2014 | Televison & Video
Insignia 39' ft screen has no pic but has sound
It sounds that the back-light inverter section circuit to your TV is faulty. It is very difficult to predict which part is defective, as per your prescription here. It will be best to contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 12, 2013 | Insignia IS-LCDTV32 32 in. Television
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Samsung PS42D7HD plasma TV has no pic no sound. Vs, Vg, Ve, Vscan, Vset volts are all correct. Heat sinks on X & Y boards are warm to the touch. RF In source and A/V In source have no output sound or...
Take your scope and see if you have any activity on the LVDS cable on the main digital board as you press the menu button or the menu on the remote. If you do not see anything then replace the main board. If you do then the plasma display panel is probably bad. Time for the bone yard.
May 08, 2011 | Samsung Televison & Video
On pic no sound blue srceen when turned on
NORMAL OPERATION. Blue screen is a volume cutoff feature when there is no signal. Turn blue screen off in the menu if you want sound when there is no signal. Another option cycle through the input sources until one is found if there are some attached and working.
Apr 13, 2010 | Element ELC-HS321 32 in. LCD TV
The pic is real brightand blue waypoint missed up
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 01, 2010 | Philips 55PW9363 55" Rear Projection...
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
