Question about Gateway (4000474) Motherboard
My gateway gt4022 won't boot. I don't think even at bios. My monitor says that it does receives any signal. I try changing the power supply but I don't think its a power supply issue since the fan kicks in and the dvd drive opens and closes. I don't what might be the problem. Any suggestions to what the problem might be? Please help its driving me crazy.
  • 83 Answers
Here are different things you can try:
Make sure there are no loose cables
Try a different monitor
Press F8 when the computer turns on.
Check to see if the lights on the keyboard turn on: this means its posting.
Posted on Jul 27, 2008
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a gateway gt4022 running windows xp. When
Probably hardware failure. To test that remove all disks and extra components and try again to boot into BIOS. If you can't then you will know for sure. If you can then take the opportunity to change the boot order and put the cd first and the hd second. Now connect an optical unit and try to boot in a bootable disk, preferably a Linux Live-CD. If you can then the hard disk is dead, replace it.
Jul 13, 2010 | Gateway GT4022 PC Desktop
Gateway Gt4022 PC Desktop
Try a different monitor (borrow one). If that doesn't work, you need to take it to the shop.
May 13, 2010 | Gateway GT4022 PC Desktop
Hello, Im Daniel and i have a Gateway GT4022 PC Desktop. When i got it it worked great!! but then a year later when i turned on the tower all i could hear was the fan from behind it blowing? Can you tell...
do your keyboard and mouse light up, do they get power, is it only your monitor does not come on and the computer seems to do every thign else ok, or is it you only hear fan noises.
im thinking would it be the monitor at fualt,
would it be the graphics card came loose.
or is it the power supply gone.
Nov 28, 2009 | Gateway GT4022 PC Desktop
I have a Gateway GT4022 that recently stopped working. When the power button is depressed, the fans will kick over for less than a second and then the system shuts down. It never gets to the BIOS and no...
Power supplies shut off automatically when one of the voltage wires is shorted to ground somewhere. This is why you see the fan kick over for a second and quit. This is probably a bad motherboard.
Jul 29, 2009 | Gateway GT4022 PC Desktop
Same exact same problem
Don't worry the ram didn't cause it. I need a little more info to solve this,like does it post? Does it light up or anything? Is the monitor getting a video signal? If it does post,turn it off & clear the cmos & try it again. You'll need to reset the date & time after this & boot order if you changed it.
Jul 13, 2009 | Gateway GT4022 PC Desktop
MOTHERBOARD shows no signs of life./MB# KTBC51GLF
Have you tested the power supply? Try switching out the power supply and see if that gets you up and running.
Mar 14, 2009 | Gateway GT4022 PC Desktop
Gt4022 boot problem
if your motherboard is getting power .try changing the boot sequence
Jul 27, 2008 | Gateway GT4022 PC Desktop
Gateway GT4022
Is Eithernet card on board or a card. If a card, turn off computer, remove card, boot up shut down reinstall card and XP or Vista should find drives and install.
Jun 23, 2008 | Gateway GT4022 PC Desktop
Computers & Internet Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
