Question about Microwave Ovens
Kenmore over the range microwave quit working 665.61639100
My microwave seemed to be working fine one day, the wife had just cooked some rice on high for 12 minutes and we went to the neighbors house. When we came back that evening nothing would work on the microwave. The control panel was dark, no interior light, and hitting the buttons did nothing. The day before we had a power surge in the neighborhood, but aren't sure if this could be related since the oven worked after the surge.
How can I diagnose the oven, and if I need to take it down from above the range, how do I do that?
Thanks in advance for your help!
  • Microwave Ovens Master
  • 9,086 Answers
My bet is that the unit overheated and the magnetron is equipped with a thermal cutout (TCO or thermal fuse) and it blew,
protecting the magnetron.
If it runs dry, it will overheat.
But a microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you do end up needing to take it down from the wall, you can download GE owner's manuals and installation instructions here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Why does my over the range microwave keeps shuttingoff our electricity in the kitchen
This may have a short in the high voltage side, rectifier or shorted high voltage capacitor. You may find it cheaper to replace the microwave, however you do need to call a repairman.
Aug 13, 2012 | Kenmore 1.7 cu. ft. Over the Range...
Panel works put microwave does not heat
It is one three things, the magnetron, cracked high voltage diode, or the high voltage capacitor "sometimes shorts"
Mar 20, 2012 | Microwave Ovens
I have a microwave that is not working, I started it and a loud pop and smell happened. Everything is still working, the lights, the motor, the clock, the ventahood, but doesn't cook anymore.
Hello & Welcome to FixYa
The loud pop sound is caused when either it is a bad fuse or the high voltage capacitor itself has gone bad and needs replacement. As everything is working fine so the problem seems to be either with the door switch or the high voltage capacitor that is bad. Please check the door switch if that appears to be fine then to replace the high voltage capacitor you'll have to take it apart completely. Please get back to me if you have any other questions.
Kevin
Dec 22, 2010 | Kenmore 63792 Microwave Oven
We have a Goldstar mv1310w microwave that the lights have quit working on. This is the light over the range that you can turn on while cooking on the stove. We put new bulbs in and I even show voltage on...
mcdevito75 here, It could be the light sockets are dirty from cooking fumes, oil etc, remove power from the sockets and clean them with alcholol and cotton swabs or paper towels etc.
Jun 28, 2010 | Goldstar MV-1310W/B Microwave Oven
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
My LG over the range microwave doesn't heat any more
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
That said, you can get free estimates on the cost of a repair but you should also consider a replacement which may be a better option for you.
What they do not tell you about over the stove microwaves is that they are constantly deteriorating due to the steam, oil, and other cooking fumes from the stove below. As a result, their life expectancy is definitely diminished.
Aug 19, 2009 | Microwave Ovens
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Kenmore 665.61639100 quit working
A microwave can be dead for many reasons.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Jul 27, 2008 | Kenmore 62702 Microwave Oven
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
782 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
