Minka Aire RC588 Remote Control
My F588 Minka Aire fan/light stopped working. The remote controller didn't turnoff the lights. The wall switch turned off the lights. I thought it was the remote controller. I changed the battery and it still didn't work (note:LED light on controller didn't come on.) Not sure what the problem is. It appears that the remote controller is bad. The receiver is possibly bad. I fan lights woulds not come on when I turned the wall switch on. Is there anything I can do to check out the receiver? I definitely need a new remote. The unit has a 9-pin connector (male/female) and the fan/lights are suspended ~ 8 ft from the ceiling. The receiver is in the switchcup under the fan. The power connections are at the top (ceiling) with the male connector located at the bottom of the fan, Can I purchase a new receiver/switchcup assembly that has as the same 9-pin connector connection? I purchased the fan/remote ~ 2000. Fan - Model F588, with RC588 Remote Adapter Kit.
  • merchant512 Sep 14, 2008
    my minkaire remote (only 3 weeks old) stopped working all of a sudden. can't figure out why.
SOURCE: Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Posted on Dec 13, 2008
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka aire wall control
Check to make sure the light wire is connected on the receiver. Also, If it is an add-on remote & you have a pull chain attached to the light, pull the pull chain for the light, Then try the remote. Otherwise, you probably need a new receiver.
Mar 01, 2014 | Dryers
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
We have a Milano Model No. F527 fan. The light comes on spontaneously at random times and the fan can only be turned on and off sometimes. Other times it works perfectly. The remote control batteries are...
Get in touch with Minka group Mr. Minka who will assist. I'm working on my same problem right now. You need to reset the dip switch in your remote or wall switch and also the same setting on the fan.
Jun 29, 2009 | Minka Aire Ceiling Fan
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Aug 22, 2008 | Minka -Aire Brushed Nickel Remote Control...
Jun 01, 2008 | Minka RC120 Remote Control
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Electro Med Services...
