Question about Dell Latitude D600 Notebook
Mains charger wont fit properly in computer
My mobicel plum tablet is not charging. its been in the charger for 3 hours already ,and it shows the charging icon on and off on the the screen. it wont start and its only 3 months old.
It can only be the charger or the tablet and if you are sure the charger is ok it leaves the tablet.
At 3 months old it should be still under warranty and so as not to invalidate the warranty it should be returned to the retailer un-fiddled with...
Sep 13, 2017 | Socket Computers & Internet
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My computer do not turn on at all.. i got new bettery and got new ac adptor charger.. stil it wont turn on... when i plug the charger it shows the blue light .. but when i trun on the power button it turns...
Take your battery out and stick it back in... make sure it is locked and fitted in there properly.... nothing wrong with the hard drive or virus... maybe you have the wrong battery... or AC adaptor... hope this helps :)
Jan 09, 2011 | HP 435768-001 - Compaq Presario C300...
It wont come on
Hello :
Have you charged it using the main charger? It's possible that just being connected to the PC isn't supplying enough power to get it properly charged. Try disconnecting it from the PC, plugging it into the charger and the charger into the wall and leave it for a while. Then try to turn it on. Do you have a car charger? Try that instead. If that didn't help , then I recommend you to replace the battery .
PLEASE RATE !
Apr 16, 2010 | Tomtom ONE GPS Receiver
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
is it the right charger? if it is it may not be fitting good because the charger might not be good or the charging port on the phone take it to a verizon store.
Wont charge
you need to try it with the correct sony ericsson charger for it , if that still does not show the battery indicator when you power on the phone then take it to ahve it looked at.
Aug 16, 2008 | Sony Ericsson Walkman W810i Cellular Phone
When i plug into car ok but when to mains nothing
First , let me say that the batteries do not fail very often. Answers here to your 3 questions in order ......
1. Your home mains charger is faulty. 2/ Your car charger is probably OK. 3/ Clip out the screen surround. Remove the 4 special STAR screws that are at the corners of the screen. Remove the main circuit board by taking out 4 smaller star screws and let it hang loose but still connected by its cables. DO NOT DISCONNECT THE BOARD CABLES. Remove the speaker . Under the speaker are 2 more screws holding a plastic bracket that clamps the battery. Remove these 2 screws and the battery clip comes off. Unplug the battery cable from the now loose main board and the battery can be removed. Fit new battery and reassemble in reverse order. NOTE , some tomtom 300's have a protective copper or foil sheild covering the main board. The screws holding the board cannot be seen until the foil is removed. Removing this foil and not repalcing it will render your tomtom more prone to interference although the tomtom will still work without it.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Dell Latitude D600 Notebook Logo
57 people viewed this question
Alun Cox
